Question about Canon imageRUNNER 5020i Copier
Envelope feed problems
I am running DL size envelopes through our Canon imageRUNNER 5020i copier, and the sides of the envelope are somehow getting scrunched in the process. The printing is fine etc, but I'm getting the impression that the way the copier feeds the paper through is damaging the paper. At any rate, the come out looking a little worse for wear, with wrinkled growing worse towards the end that comes out of the copier last.
    Scholar:
  • 56 Answers
The problem is due to the type of envelope materials you are attempting to print on. The envelope stock (paper) is much too thin or lightweight. This is the primary cause of the wrinkling.
I would suggest that you switch to a heavier envelope material, but try to stay away from linen envelopes, as these will tend to wear down the fuser mechanism faster that normal. Most printers and copiers all have this classic problem.
I worked as a design engineer for Kyocera-Mita America for nearly 6 years and have seen this problem many times over and the only available solution is to change the stock. I (KMA) did work with a company in Canada who developed a specialized mass envelope feeder system for many of our systems. However they made major design changes to the feed mechanisms and feed roller pressure to deal with lighter stock materials.
Hope this information helps you out.
Cheers,
Keith
Posted on Oct 23, 2008
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I want to print envelops on my office canon imagerunner 5570. i cant? help.
use the stack bypass for envelope printing.there u can choose the paper size as envelope depending on the size and also u can set ur own XY size for the envelope
Jun 03, 2011 | Canon imageRUNNER 5570 Copier
How do I print envelopes using my Canon Imagerunner 1023N?
load your envelope in stakbypass and chose free size and enter your envelope size then you have to custome size your pc as envelope then print your document.
May 17, 2011 | Canon imageRUNNER 1023iF Black and White...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
HOW DO I PRINT AN ENVELOPE ON THE IMAGE RUNNER 3025
you must put it in the bypass and put the size and the kind of the envelope
Mar 26, 2010 | Canon ImageRunner 3025 Black and White...
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
My Canon imageRUNNER 2200 won't print envelopes. How can I get this function to work?
Put the evelopes in the bypass tray.As soon as you insert envelopes on the touch screen different papersize options will apear.Select the envelope size.Then you are set to copy or print on the envelope.
Sep 30, 2009 | Canon imageRUNNER 2200
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print envelope on MX310
Note:
    Note:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon imageRUNNER 5020i Copier Logo
335 people viewed this question
old marine
old marine
