Question about Hitachi 50DX01B 50" Rear Projection Television
60" Ultravision picture problems
Picture shows up blurred with lines thru it. Often times it will go to one picture and another picture just above it that is different colors from the top picture then the bottom picture? Is this a problem that can be resolved at home?
    President:
  • 3,130 Answers
HMMMM Dual pictures This is a problem that every projection TV runs into at least once or twice in its lifetime. Its the old convergence IC falure thingy. These IC's go bad and should be replace all at once. These are not consumer replaceable unless you have had training in the electronics or TV repair fields. Please call out a pro to assist you with this repair as A TV is not the place to experiment in because of the HI voltage and saftey issues. Good Luck
Posted on Jul 29, 2006
I had a problem on my sansui TV its shows Rambo
IS your TV's picture blurred? and at the same time..it's shows rainbow?..If so? The problem is from the CRT socket. Replacing the CRT socket can cure these picture problems.
Oct 03, 2014 | Televison & Video
Picture blurred with yellow cast
Its a Dlp that uses a lamp---the yellow cast suggests a damaged Optical light Engine----Google the model number with problems and you may learn more---if the engine is bad it may not be cost effective to repair the set.
Dec 08, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
VIDEO CAMERA SHOW BLURRED LINES WHEN PLAYBACK VIDEOS
sir!
Clean the lence cover of your camera it might sovle your problem.
Oct 14, 2008 | Video Cameras
FE-170 Blurred photos
ccd may be going out.. try doing a reset thru the menu or else..repair
Aug 31, 2008 | Olympus FE-170 Digital Camera
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision Digital TV dark picture
Looks like
1. A Cold solder in the Video Output stage power supply.
2. A bad Electrolytic Capacitor in the above Video Output stage.
I generally do not waste time in attempting to locate faulty capacitors. There will be only 6-8 pf them in the above stage / section,m and the klot of them would collectivelyt not cost more than 3-4 $ equivalent, in india. Just blindly replace the lot, and the set is ready in 30 mins.
Dunno how much they will cost in your country. Try to look for a 100mfd, 160V Capacitor. Close your eyes and replace. generally does the trick.
Nov 13, 2007 | Hitachi 32UDX10S 32" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Hitachi 50DX01B 50" Rear Projection Television Logo
76 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
