Check see tail light lens has 4 screws holding it in place.if so remove 4 screws then remove rear tail light lens then replace tail light bulbs.if you have trouble replacing tail light bulbs the auto parts store sales person will help you free of charge and help you replace bulbs.i have seen auto parts stores sales person help people replace batteries,windshield wiper blades and light bulbs in vechicle if you have trouble fixin it your self.
Rear iignts in rear na, removing and instaiiing
Fig. 325: Rear Lights In Rear Lid, Removing And Installing
Courtesy of VOLKSWAGEN UNITED STATES, INC.
Removing
CAUTiON: • Switch off all electrical components.
. . Switch ignition off and remove ignition key.
o Turn light switch into "0" position.
o Open cap - 1 - for warning triangle.
o Rotate quick-release screw - 2 - counter-clockwise 90 C
and remove cover - 3 - from luggage compartment lining - direction of arrow -
Fig. 326: Removing Bulb Socket From Housing, Pressing Catch
Bracket Downward
o Disconnect electrical harness connector
o Remove bulb socket - 1 - from housing, press catch bracket
- 2 - downward - arrow - to do so
Fig. 327: Identifying Nuts, Clamping Bracket, Inner Tail
Lamp, And Clamp Mounting
o Unscrew nut - 2 - and remove clamping bracket - 1 -
o Remove nut - 4 - and remove inner tail lamp - 3 - toward
outside
o Remove clamp mounting - 5 - from body cut-out
Fig. 328: Identifying Clamp Mounting, Nuts, Inner Tail Lamp,
And Tabs
Installing
Installation is the reverse of removal, noting the
following:
NOTE: • Make sure seal between body and tail lamp housing
seals properly.
. Attach clamp mounting -2 - at inner tail lamp and screw on
nut -3 - loosely.
. Attach inner tail lamp -4 - at body cut-out and make sure
grip tabs - arrows - of clamp mounting rest against body cut-out
. Slide clamp mounting - 1 - onto threaded pin of inner tail lamp and tighten nuts - 3 - and -5 -.
