Etronix Flat Screen Monitor PROBLEM!
When I turn on the monitor, it flashes white for a split second then turns off making a popping sound in the speakers. The computer is plugged in and it has power. Could I do anything to help my poor monitor?
Etornix flat screen monitor
Model: A170E
Thanks in advance.
    Genius:
  • 1,605 Answers
What video card and what monitor are you using????
what operating system???
what make of PC??
need more information.
Posted on Oct 22, 2008
Acer x213w monitor
try to set up different frequncy of monitor....
try monitor with another comuter, or notebook....
let me know...
Jan 13, 2014 | Computers & Internet
My monitor has sound and the little green light is on, but the screen is black no matter what I do. Tried rebooting, checked connections, shined flashlight, etc. I've noticed over the past few days, the...
Make sure it is plugged into the right connector on the back of the pc. If you have intergrated video and a later installed video card make sure it is plugged into the right one. Does the monitor say "no signal"? Have you tried a different monitor to verify that the connection works. Also try a different cable, as the cable could be bad.
Nov 16, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
White screen at startup
The white screen is caused by the power supply board not providing the correct voltages to the display driver board. Check our web site at: www.ccl-la.com We have repair guides for many LCD monitors and there is a guide that will work for your LT982 monitor. If you don't want to do the repair we do offer a repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 10, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Apr 09, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Flat Screen Monitor
hello can someone help me?? the problem is when i turn the monitor on i just can see shine white i can do anything my monitor is del E197FPf lcd thanks a lot
Jun 25, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
668 people viewed this question
David Payne
David Payne
