Question about Canon ZR100 Mini DV Digital Camcorder
Lines through the playback
Can you explain to me why my playback has gray lines through it?
  • 240volt Oct 22, 2008
    lines through the playback problem and when switched on
  • kaneemis Nov 03, 2008
    i have grey lines across screen during playback. I tried a head cleaner, but still the same problem.
  • 10 Answers
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. The person who helped me solve this said: "the speed isn't linked with the last time you recorded on it. Frames have an A/B part to them. If A is hitting B instead of A, a line appears. I would try the head cleaner first, then blacken your used tape (keep lens cap on and record in a quiet room) and try that."
My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Posted on Nov 28, 2008
  • 44 Answers
Generally the Grey Lines are either the heads are dirty or one of the heads is bad and the video drum needs to be replaced (since you tried a head cleaner most likely the latter)
Posted on Nov 05, 2008
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Playback problem
have you cleaned the heads lately?
Dec 25, 2008 | Sony Handycam DCR-TRV240 Digital Camcorder
Horizontal lines on playback on my camocorder samsung sc-d353
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Feb 21, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
On playback, the video has gray lines across it
Dec 28, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Horizontal lines on playback screen
Nov 15, 2007 | Canon ZR100 Mini DV Digital Camcorder
Wide Horizontal lines on playback
Wide bands in the playback video indicate a clogged or defective video head assembly. If your cleaning tape appears to resolve the problem, the heads are getting contaminated. I would not use the same tape in this unit. Try cleaning the heads and then use a brand new tape to avoid clogging the drum assy again. If this does not resolve the problem, the drum assembly will have to be replaced. Hope this helps. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
328 people viewed this question
Top Canon Video Cameras Experts
KellySD
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
