Question about GE 24 in. GSD3210Z Built-in Dishwasher
Door won't open
We have a brand new (two weeks) GE Profile dishwasher. We went to put away the dishes and the door of the dishwasher will not open. The latch used to feel spring-loaded, but now it is loose. What do we do?
  • JacksonLee Nov 02, 2008
    Is there a quick release of some kind? More than half my dishes are stuck in the dishwasher.
    We've actually had the dishwasher for several years now and this is the first problem we've noticed.
  • ntw99 Jan 01, 2009
    This is a new house, we've been here 2 weeks and I have used this GE Profile dishwasher 8 or 10 times. This isn't a good sign.
  • 417 Answers
Call the store where you bought it or the GE repair service, you should be covered under warranty, this should not happen on a new machine.
Please remember to rate this solution.
Posted on Oct 22, 2008
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
Nov 10, 2013 | GE 24 in. Profile PDW7800 Built-in...
I own a GE Profile Trition quietpower III GSD5940F00SS dishwasher. The dishes, particularly the mugs and cups, are not getting clean.
Your sprayer arms may be clogged. You can remove them by loosening the screws holding them in place. Flush them with the sprayer at your sink. If you can SEE residue (parts of paper labels, bone fragments, fruit peel pieces, etc) remove them with a tweezer.Reinstall the spray arms and see if that works.
Three more ideas:
(1) run a cycle without dishes OR detergent and use 1/4 cup of white vinegar instead. This will break down soil and "gunk" and help your dishwasher run more effectively.
(2) use an old toothbrush and clean the underside of the door INSIDE the dishwasher. The door will be open and you just brush the bottom of the open door on the INSIDE of the dishwasher. A lot of "crud" gathers there and can be redeposite on your dishes. We seldom think to check that area.
(3) the pipe that carries water to the upper sprayer arm MUST fit against the outlet in the back of the dishwasher. If it is dislodged or not seated properly, the water won't flow to the upper sprayer arm.
Hope one of these suggestions helps. If it does, please rate my suggestion. Thanks.
Jun 03, 2011 | GE Dishwashers
Dishwasher door lock does not unlock on my GE quiet profile 3 dis
Sounds like you door safety interlock switches, are faulty, these can be easily replaced, at reasonable cost.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-door-switch
http://www.rd.com/how-to-repair-a-dishwasher/article18243.html
http://www.ehow.com/how_5676347_replace-door-switch-dishwasher.html
A DIY links above. it is pretty easy, you may even be able to adjust your one too.
Apr 06, 2010 | Dishwashers
Our GE Profile dishwasher will not open. I have
door latch must have broke take a knife and jimmy the latch
Dec 10, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Oct 16, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Granddughter stood on dishwasher door and now it goes down too far when opening. Spring assembly (pulley type) is FINE...but door goes so far down bottom shelf nearly breaks dishes when pulling out
This happens when people leave the door down, I've seen it many, many times, sometimes the door/hinge assembly can be replaced or even bent back, sometimes it totals out the unit...Good luck !
RMK...
Retired GE Factory Service
May 21, 2009 | Dishwashers
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. GSD3210Z Built-in Dishwasher Logo
159 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
