Question about HP PSC 1350 All-In-One Thermal Printer
Connect HP printer to my PC
I changed my printer and I'am using now a HP 1350. I don't have the CD for software and the printer can't be connected. Could you please tell me where I could go to unload the software? Thanks
    President:
  • 1,901 Answers
Here is a link to HP Support for your printer:
PSC 1350 Support
Select your operating system and then download the software you need/want, or order a CD.
Posted on Oct 22, 2008
  • 849 Answers
Cannot connect 1350 printer with windows 7
The printer PSC 1350 is not compatible with Windows 7.
We can directly plug and play it to use the Printing Part.
And in order to scan, only way to do is through Windows Application.
There are different softwares and ways to scan, use as per your choice.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01884960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
May 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
HP printer F4180 series doesnt print - transferred from older xp pc to newer vista pc using installation disc
may be the driver disk which yo using that if for xp if you have vista cd install it.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 24, 2010 | HP DeskJet F4180 Inkjet Color All-In-One...
C5180 all in one is not connecting via ethernet.
Before you begin: Check requirements Make sure you have the following items:
  • One of the following types of wired access points or routers: Ethernet router, switch, hub, or wireless router with Ethernet ports
  • A computer that connects to the wired access point or router
  • A Category 5 Ethernet cable to use for the HP product. (Do not use a standard telephone cable.) Figure 2: Cable comparisonc01710115.gif 1 - Ethernet cable 2 - Telephone cable (do not use) Although an Ethernet cable looks similar to standard telephone cable, each has a different plug and a different number of wires. The plug on an Ethernet cable (also called an RJ-45 connector) is wide, thick, and always has eight wires. The plug on a telephone cable is narrower and has between two and six wires.
Are you changing from USB connection to Ethernet connection?If you previously installed the software for a USB connection and now want to change to an Ethernet connection, follow these instructions to remove the USB installation before continuing.
  1. Click Start , click Printers and Faxes , and then right-click the icon for HP product.
  2. Click Delete to remove the product.
  3. Disconnect the USB cable from the product and the computer.
Step one: Connect the HP All-in-One to the network
  1. Remove any plug or protective cover from the Ethernet port on the back of the product. Figure 3: Remove plugc01710117.gif
  2. Connect the Ethernet cable to the Ethernet port on the product, and then connect the other end of the cable to an available port on the wired access point or router. Figure 4: Connect the Ethernet cablec01710118.gif
  3. Connect the power cord to the product, and then plug it into an electrical outlet.
  4. Turn the product on.
Step two: Decide whether to install with the product CD or download the software Don’t worry if you don’t have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use:
CD Download For a new product: CD installation is a quick and easy method. If you do not have a CD, you can download the software you need. For an older product: CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released. Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released. About the software: The software on the CD is current to the date of the product release. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.Step three: Install the software
Jan 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
C4400 scanner printer will not scan to pc.
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.also change the usb cable and the usb port.
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
I want to download the printer on my laptop and I can't find the disk, can I do it from this site
Not directly, but you can go to this HP site:
PSC 1350 Support
Select "Software & Driver Downloads".
Then select your operating system.
A list of avalable software and driver packages may be downloaded. There is also a link on some OS to purchase a CD if desired.
Any problems, just Comment back.
Thanks for using Fixya.
Jun 26, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP psc 1350 missing scanner software
please visit the link bellow and find the software for that
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=306888&lc=en&cc=us&dlc=en&lang=en&cc=us
after you visit the site and select the operating system and download the software or driver
Nov 11, 2008 | HP PSC 1350 All-In-One Thermal Printer
Hp psc 1350 printer
i cannot re-install my hp 1350 all in one scanner. i have uninstall and re-install the printer driver was unknown. how can that be possible even i dont have the cd that comes with it.
Feb 02, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
61 people viewed this question
Ben Johnson
