Question about Sony KP-41T65 41" Rear Projection Television
Red screen My screen is all red. I was having problems with picture being blurry but after 20 minutes or so to warm up it would get better. The longer the set stayed on, the better the picture would get. One day I turned it on, got the same blurry picture and 5 minutes later it was all red-no picture at all. Can anyone help? thanks
    President:
  • 3,130 Answers
It sounds as though your Picture tubes are getting weak or theres a bad capacitor in the screen drive circuit. The only way to tell would be to call in a tech to diagnose this problem with his test equipment. A tv set is not a place for an unexperienced person to play with. Good Luck
Posted on Jul 29, 2006
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
LCT TV picture blurry with black smudges until it warms up
No easy way short of monitoring with a scope and or voltmeter, based on age of set I would first "look" at all the filter caps in the main power supply--bad ones when they get hot can regain some function:
Dec 09, 2012 | Televison & Video
Static noise and blurry screen
You need to take your TV set to Service Center, because the inner parts, especially the flyback transformer, been damaged or worse, the connector broken, that's why you can hear the noise.
Mar 07, 2010 | Symphonic ST420FF 20" TV
Sony KP-61HS10 st start up blurry gets better the longer its on
You have loose solder connections on the convergence amps.This is a common problem caused by heat within the unit.If you can solder you can fix it.
Jan 12, 2009 | Sony KP-61HS10 61" Rear Projection...
Blue wave across screen
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
Taking pictures
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
Screen went blurry 20 minutes later no picture no sound just red flashing light on front
These sets had bad welds in the gun assemblies of the picture tubes. Now, one of the tubes has failed (shorted) and the cost would be too high to replace all three.
Mar 02, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv help
Symptom: PICTURE PULLS
Cause: DEFECTIVE D702,D703,D704
Symptom: DIGITAL CONVERGENCE WON'T ADJUST
Cause: DEFECTIVE DCU
Jan 14, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Oct 06, 2006 | Zenith Z46Z83D 46" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
