Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic va720 monitor
My monitor power stays on but the picture will go black after a few seconds. I changed my cables and still the same. What can I do?
  • 1 more comment
  • standroege Oct 22, 2008
    The screen will come on for a few seconds but then goes black. There was no powersurge.
  • Anonymous Nov 06, 2008
    I have a similar problem with the same model in that it blacks out.
    Actually I think it may be on but if it is the intensity is way way dim.
    If I switch, to another machine - same problem. Both machines are Dell, but all other monitors seem to work on them.
    If I turn the power off then back on the image that is supposed to be
    there flashes briefly, enough to see the pictures/graphics - in a
    stable frame - that may be on the screen but not long enough to read
    anything. There is no scrolling or otherwise horizontal lines or
    artifacts to indicate there is anything wrong with the image being sent
    to the monitor.
    I estimate the time it flashes on to be about half a second or less.
    Any suggestions?
    Is it worth fixing? What about costs if I do?
    I hate to throw away an otherwise good monitor. There is enough landfill.
    Thanks.
  • jefflong65 Nov 26, 2008
    I have the same problem with my monitor. I've tried booting in "safe mode" to get the lowere refresh rate but still, the screen only stays on for about 2 seconds then it goes blank and the green power light stays on. I've tried it on other computers and it still has the same problem. I'm thinking the monitor is fried or at least a new monitor would be cheaper than fixing this one. Anybody have any ideas?? Thanks.
  • 1,498 Answers
When the monitor does come on, is it during the POST (when booting)?
Then blanks out after the system starts up?
If this is the case, the refresh rate may be set too high. CRT type monitors scroll rapidly when this happens, but LCD's just Black-out.
To check, try booting in 'Safe - Mode' (pressing F5 or F8 during boot). This will boot your system with a display setting at a lower resolution and refresh rate.
If your monitor functions normally, we're on target.
If it still blanks out, I'm barking up the wrong tree.
Comment me back with the test results. We'll act accordingly.
Mike
Posted on Oct 26, 2008
    Sergeant:
    Champion:
  • 331 Answers
Is it that whatever u try the screen does not come alive???????
was there a voltage spurge or something maybe an IC blew up..
could u tell me when did this happen
Posted on Oct 22, 2008
  • Varun Kumar
    Varun Kumar Oct 22, 2008
    then there still might be the IC problem........
    maybe it is the CPU it might have a prolem with the graphics card ..
    try to use the moniter on a different cpu to check this out.........
I have two Viewsonic VA720, attached to the same computer. About a month ago on of them decided to turn white when it powers off. It will stay that way for a long time, and finally to black. Any idea?
ben7295, Internal power supply failure. Watch some DIY repair videos at YOUTUBE. You may be lucky and find one just like your"s being repaired there. Then you will need to make big decision! Attempt a DIY repair or just trade in for new unit??? After doing your research, return here and rate this response if it helped you make correct decision.
12fixlouie
p.s. "white screen, black screen, = POWER SUPPLY PROBLEM
Aug 06, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic va720 monitor flickers / goes a little dim. wiggling the power cord often helps.
then change the power cord...there may ba loose connection...or the pins int he cable is not getting full power
Dec 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
What voltage do i need for my ViewSonic VA720
Monitors and PCs (amongst other things) use a fairly standard power cable. You should not need to worry about the specifics as there is generally no transformer needed for a monitor.
Oct 26, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VG700b bug
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
May 20, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Va720 view sonic monitor
To plug out the dont need to remove any screws only by applying a little force you are able to pull the cable out.
Apr 06, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
240 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
