Question about Panasonic TH-65PHD8UK 65 in. Plasma Television
Panasonic 65" TH-65PHD8UK Commercial Series RGB Problems
I have the commercial series Panasonic plasma, model TH-65PHD8UK. My television has been good to me however, the component feature is not working right.
At first I thought the problem was one of the blades, so I took the blade out of my TH-42PH9UK and put it into this television. This did NOT fix my problem. Standard video works fine, as well as VGA but I cannot get the television to display component right.
I do not have the HDMI blade to test this feature out. The television is no longer covered under warranty, manufacture date is August 2005.
Basically, what happens when I connect a component cable is the screen is pretty much green in color. Green takes over the quality of the picture, though some of the other colors do pass though.
FYI:
Yes, I am connecting the component cable correctly to the television.
Yes, I have tried switching the blade.
Yes, I have tried different cables and sources.
  • 616 Answers
Well, then you better contact a service technician.
Posted on Sep 26, 2010
Pls tell me the watt for tv model th-65 pv 500m
The closest thing I can find to your plasma TV is the Viera 65-in model TX-P65VT20E, which consumes 635 Watts. This should be close to the power budget for your unit.
Reference:
http://panasonic.net/avc/viera/eu2010/product/vt20_plasma_spec.html
Sep 13, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic lPT-51HX42F TV does not turn on but the red light in front is solid red.
The power module may need replacement, but there amy be other problems Panasonic has a code built in if the light blinks count the blinks and they will know the source.
Mar 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
When plugged into outlet will not turn on panasonic viera 42 inch
Power supply board is dead.Tries wbsites Shopjimmy.com,Ebay.com to buy a refurbish power supply board to replacement.
Mar 13, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic plasma error codes
code erreur 12 model panasonic th-46pz81e aider mois svp
Sep 15, 2009 | Panasonic TH-65PF9UK 65 in. Plasma...
How work this peavey? is good
The CS series from Peavey is their workhorses. They are very good and reliable. I have been using variation of the series now for nearly 20 years with no problems. CS stands for Commercial Series meaning that it is intended for commercial use.
Aug 21, 2009 | Peavey CS 1400 Amplifier
Volume suddenly turned down during commercial
shut off the all BBE and surround and the AL sound page 27 of the manual.
Feb 22, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH50PH10 Turn off Automatically
Hi, if your plasma flashes 10 times it means that there is a problem with the sustain driver. This could be an intermittent problem, such as when the set heats up. It should be returned to the dealer as it is under warranty.
Dec 16, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-65PHD8UK 65 in. Plasma Television Logo
109 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
