I have a 1995 52 inch rca projection tv.it will cut itself off and on.stays off for 10 to 15 minutes before it can be cut back on.when it is on it works fine and picture is fine
  • tonypruitt19 Oct 22, 2008
    thanks so much for your help.im going to open it up as soon as i can get the time.thanks so much!have a good day.
  • tonypruitt19 Oct 23, 2008
    ive tried to find a loose connection and couldnt...any helpfull hints?the tv cut off today and i havent been able to get it back on yet.the green indicator light will flash about three times when i push the power button.
    Sergeant:
    Champion:
  • 227 Answers
Hello i think that you have some loose connections or cold solder wich is the same, just open the set carefully and tap on the boards with something plastic do not use your bare hands.when you isolate the board with the problem pull it out, then go to radio shack and buy a soldering iron and some solder, resolder the bad connections you will need also a bright lamp. i beleive that you can do it yourself.
good luck
caypianan@yahoo.com
Posted on Oct 22, 2008
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
Oct 27, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
Picture goes off on its own
BAD SOLDER JOINT ON L14401
Apr 11, 2009 | RCA F36650 36" TV
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
Television
maybe the power switch of your tv is loosen,if not you may coldsolder the components of board of your tv.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen TV shuts down
Sounds like an electronic part (a resistor, a diode, etc) that stops conducting electricity when it heats up to a certain point. Maybe it physically loses contact on its circuit board due to a bad solder, or the part itself is internally defective. Unfortuantely you'll need an expensive professional repairman to diagnose it. TVs have high voltages, ya know, and can kill you if you go mucking around inside.
Feb 24, 2007 | RCA D52W19 52" Rear Projection Television
Convergence setup menu gone
No rest on this model other than unplugging to let it return to factory default. If your a tech .. Check R19722 and R19703 for open. Both 750 K. these open make the convergence menu to be gone.
Jul 13, 2006 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
