Question about Pioneer SD-532HD5 53" Rear Projection Television
Problem with board
Last March I had a new board put in my Pioneer Projection T.V. Now I am having a problem with it. The screen moved up a little. I called the t.v. repair shop who put it in since it cost me $600.oo. Now the repair man said it was going to cost a couple of hundred dollars to fix. I feel it should not cost anything since it is a new board. Can I have help here.
    President:
  • 3,130 Answers
Problem is theres several boards inside this set and it may not be the same repair. Even if it was a shop cannot warranty a set for more then the manufacturer warranty's the boards. They , the manufacturers only warrantee these boards for 90 days. Its just something that happens .. Its not planned or anything. When was repairing pioneer sets I ran into this situation all the time. As a matter of fact with any projection set I ran into this situation. Its like if you take in your car for brakes, then a month later the water pump goes bad, is the mechanic going to fix the water pump for free?? I think not! Its the same thing as there are hundreds of parts in a TV set, and just because you replace a few of them , you can not garantee all of them. See my point?? Good Luck
Posted on Jul 28, 2006
My pioneer pro-151 fd do not power on
Hello!
known problems with this brand is: multiple solder joints failures, plus near empty electrolytic capacitors. Those, usually won't "bloat", compare to modern panel TVs. Instead, you may see a little grease puddle under capacitor, which is escaped electrolyte. Or, nothing! First move is to re-solder ALL the power PCB connections, then put board back, connect all the plugs and wires. Try. It might work in many cases. If not, better to call for in-home repair! If it takes more, than just a soldering, that's a pro job.
Good luck,
Alex.
Jan 18, 2012 | Pioneer Televison & Video
Hi My name is Dieter and I have a Pioneer Elite Pro-610-hd which keeps loosing the picture and sound.
The tv "LAMP" LED light indication front of the screen panel flashes?When was the last time u replaced the tv projection lamp on this tv?If the last time u replaced the projection lamp was like 1/12 or 2 years ago?The tv been on and used like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Sep 19, 2010 | Pioneer PRO-610 58" Rear Projection...
Rainbow colours on the screen
The projector is starting to go out in it. Depending on your financial situation, you can take it to a shop to have it looked at, or replace the TV. Depending on how long this has been happening, the Pioneer projectors usually last about 100 hours once this happens before they burn out completely.
Apr 30, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Fluid leak ws 65807
It sounds like the coolant leaked from one or more of the projection tubes. You may need to replace the affected tube assemblies.
Sep 17, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Black horizontal line moving across screen with PS3
Loose connections in the AV board. Re solder . Did you try in video 2 or 3 ?....But Am suggested re solder AV board and connectors. I hope this help you I am here any time thank you!!!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Rolling screen 65813
there is a small surface mount IC location num IC9C25 on the board next to the DM. it is at the bottom right corner if looking from the back. this a 9v regulator P/N BA09FP this might be your problem. be careful taking it off because you do not want to damage any traces. i suggest taking the input board off.
Mar 23, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Replacing power board on pioneer pro 200 elite
364.00 for a new Power/deflection board through pioneer. i am including a link to their site. You may find it cheaper someplace else on line, but pioneer will have better quality parts. hope this helps. heres the link.
http://parts.pioneerelectronics.com/model.asp?modelNum=PRO200
Jan 15, 2008 | Pioneer PRO-200 60" Rear Projection...
Green problem
sony has extended the warranty on this problem you need an optical block contact sony for an authorized servicer
Jan 12, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Pioneer PRO-710HD 64 in. Rear Projection
could be your projection lamp.. check the manual for how to check
Oct 01, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Taking apart and moving a 55 inch projection TV
hi do this as last option! there is 30,000v inside the tv!! you can die before you even think about it the only way to do soo is unplug the T.V from the wall for a week at least (so the volt will dissolves) you can turn the tv on its side you will have a problem if it will get a slap or will fall in my opinion just take on its side....but its your decision JUST BE CAREFUL PLEASE!!! good luck
Mar 20, 2006 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD-532HD5 53" Rear Projection Television Logo
41 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
