Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Green lines in TV
Off and on for the last 6 months my TV will get these horizontal green lines in it. Sometimes it's just a few lines here and there and sometimes they are all over the screen. (see picture below) There is no specific time when this happens and it comes and goes. Sometimes the picture is perfect. The TV is 5 years old and has been used very very little. Does anyone have any idea what is wrong with it?
    Top Expert:
  • Samsung Master
  • 79,865 Answers
Take the TV cabinet apart and unplug and replug all the circuit board connectors, that may fix the issue.
Posted on Jul 06, 2017
Soulvisitor
  • 1113 Answers
SOURCE: arching horizontal
You have convergence failure
See this and this
Call a Tec if inexperenced
Posted on Jan 26, 2008
ahhsoo69
  • 167 Answers
SOURCE: HLN507W Samsung 50" DLP
hello yes it sound's like your fly back transformer is going bad. to me.!!! just have to wait and see. wont take long if it's doing what you say. "hope this help's you "good luck"
Posted on Aug 20, 2008
rhozel2010
  • 269 Answers
SOURCE: horizontal green lines appear now and then; not clear picture
i think the color wheel is in need of calibration.
Posted on Aug 11, 2009
raklein62
  • 360 Answers
SOURCE: rolling green horizontal bar from top to
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Posted on Oct 25, 2009
eddiepeezy
  • 130 Answers
SOURCE: Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
Posted on Feb 04, 2010
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months...
no solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Sep 07, 2010 | Samsung HLP5085W 50" Rear Projection...
I have a 51HW40 sony TV. A few problems green horizontal retrace that curves flashes green and turns off (about 2 times a month) I wait turn it back on and its fine Codes that have been tripped: 6: Low b ...
Hello: Have you tried to adjust you Green Screen control on the focus block assembly. located behind the front panel assembly. Here is a solution that might help you, turn off the green by turning off this control, make sure u look at the block and make sure you are not turning the green focus knob instead of scrn crl. Turning the control slowly to the left the retrace lines should disappear as the green video darkens. Then turn the control slowly to the right just until the retrace lines reappear, then turn back slowly left just until the lines go away. If the screen is Blanking on green tube only then you have a video blanking problem on the main signal board. Or possibly a IK bias problem. It is also possible that the green CRT is defective. The FBT is not bad because the screens are lighting up indicating you have high voltageand heater voltage which is derived from one of the secondary windings of the FB. If it is a Blanking problem i would look into replacing the A Board assembly.
Sep 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Green picture with horizontal green lines...
John,
First, Id like to know how old is your unit? Also, the lines indicates in issue with regards to the lifespan of your tube. The dominant green color has something to do with a malfunctioning ray gun of your tube. However, i had encounter a unit that was resolved by simply resoldering the circuitry of same problem.
Why dont you try to resolder the board first.
Response is highly appreciated.
chris
Mar 29, 2008 | Toshiba 32AFX61 32" TV
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Green Convergence
Hello, I have the same problem and was told that I needed a new convergance chip. They told me who deals in the problems where I live, (TV Repairman) It will cost me 300 for a six year chip and 350 for a life time chip! I was told by the repairman that these chip only last up to 6 years if they are not lifetime. I see alot of this same problem going on right now. These tv were manufactured in 2001, but no one was ever told that these chip would need to be replaced in so few years after spending all that money on the TV. Pasonic would not tell me the price of the chip nor how to get one,were very unwilling to help with the problem other than telling me who do go to locally, so you would have to go thru a tv service where you are.
Jul 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
