Question about HP PSC 2355 All-In-One InkJet Printer
Out of Paper. Load Paper Error
I have a HP PSC 2355 all-in-one Printer, and I keep getting Out of Paper, Load Paper error. But there is paper in the paper tray. I have put not to much and not to little paper in the tray. I have tried to reinsert the paper back in the tray & even reinstalled the drivers with updates. I have unplugged the power cord and the USB cable option also still have error. this printer is not very old. Please Help! Thank You!
  • 1 more comment
  • kanava_1 Apr 03, 2009
    its not a paper jam.... It says
    Load more paper and press the Enter, Resume or OK button on the hp psc.... but my printer has paper and i tried cleaning the rollers, but it still does not want to feed paper. I'm using the hp psc 1610
  • Anonymous Mar 17, 2014
    My HSP PC1610 is claiming to be out of paper even though the paper tray is full (i've tried varying amounts) and the paper doesn't have any creases etc
  • Anonymous Mar 23, 2014
    Accidentially pulled out the paper tray of my EPSON 7250 printer. How do I put it back in?
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Posted on Mar 13, 2008
I have the same problem with a new psc 1610. The paper is not grabbed. Their might be a sticky spray for the rubber rollers to help? Handfeeding each page currently (sigh). All else works well though. good luck.
Posted on Jun 25, 2007
SOURCE:
Getting an error message of 0xb900009f on my HP
Most likely problem is paper Jam of some paper particles are still present on paper pick up rollers gears, printer needs physical inspection
Aug 05, 2012 | HP PSC 2355 All-In-One InkJet Printer
My hp psc 2355 keeps on sayin CARRIAGE JAM
Hey
I gues this video in youtube sloves your problem
please let me if you face further problems
Thanks Anil
Jun 14, 2010 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 printer gives "Memory trashed?" error
Disconnect the printer from the computer remove loaded paper, turn it off & disconnect it from AC for at least 30 mins.That should resove your problem.
Oct 01, 2009 | HP PSC 2355 All-In-One InkJet Printer
Printer cartridge keeps jamming
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 24, 2009 | HP PSC 2355 All-In-One InkJet Printer
Error load paper?? but already have paper!!
what i might do is to remove that application using control panel, add and remove software. uninstall the printer software disconnect printer from pc, reboot/restart, go to printers in control panel remove all printers listed, then make sure you have right software for your printer. shut down this time.reconnect printer cable and boot back up. reinstall the soft ware with printer on.
Aug 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp 2355 all in one
Does the same message come up when you try to copy?
Oct 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
2,057 people viewed this question
Clive
Clive
Thomas F. Schneider
