Question about Fuji FinePix Z100fd Digital Camera
Charging I was hoping you could tell me if the USB will be able to charge the camera when it is connected to the computer.
    President:
  • 2,712 Answers
No, it will not. The digital camera uses separate AA batteries, and cannot be charged via USB like say a GPS navigator..
Posted on Oct 22, 2008
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
Nikon coolpix s5200
Please try removing the battery and after a few moments replace the battery. This should "reset the camera. It has the same effect as a cold boot on a computer.
Never try o switch on a camera, when an USB cable is connected. Only certain camera's, and only when special software is installed on the commuter, can work with the USB cable.
Most cameras, play "dumb" and only accept 5 volt, to charge the battery, or will transport pictures to the computer when connected and the correct software is installed.
I hope the camera will work again.
Success
Jul 25, 2014 | Nikon Coolpix S5200 16 Megapixel Digital...
When I try to charge My camera the screen says MSDC
If you're charging the camera by connecting it to a computer's USB port then this is perfectly normal. The camera is merely telling you that it recognizes a connection to a computer.
If you're not connecting the camera to a computer, then please reply to this post and specify the make and model of your camera.
Jan 25, 2014 | Cameras
Panasonic Lumix DMC-ZS15 will not connect to pc and will not charge. Bad card on camera?
Are you turning the camera power on when you attempt to charge the battery? The camera power needs to be "OFF" when charging. When connecting the USB cable to your computer the camera must be "ON" and in the "PC" mode. Hope this helps.
Sep 04, 2013 | Panasonic Lumix Dmc-zs15 12.1mp Digital...
My dcr sr 80 is not charging
Depending on your camera, the battery may be able to be charged on the camera or by using a separate battery charger. Refer to the section below that relates to the charging method you are using.
Charging while the battery is attached to the camera:
  1. Make sure the battery is firmly attached and the AC adapter is securely connected.
  2. If your camera can charge the battery with a USB connection, use the built-in USB cable to connect it to the computer. If you use a USB charger instead of the computer, check the compatibility of the USB charger.
  3. Turn off the camera. The battery is does not charge if the camera is turned on.
Charging using the battery charger:
  1. If the CHARGE lamp does not light or blinks when charging, the terminals may be dirty. Wipe the dust away with a dry cloth and charge the battery again.
  2. Make sure the metal contacts on the battery are free of corrosion.
Dec 28, 2012 | Sony Handycam DCR-SR80 HD Camcorder
How do i know if my sl600 is charging? I have it pluggedin with the usb cable attached to the ac adapter. and the tiangular shape is orange. Does this mean its charging and how do i know when its complete
I'm glad to provide the information about charging the Camera. You can charge the Camera either using AC adapter or by connecting to the USB port on the Computer. Please make sure that you're not connecting AC adapter to the Camera when connecting to USB port on the computer. You can connect the Camera to the computer for more than 150 minutes(two and half hours) to fully charge the battery.
You can check the status of the LED on the AC Adapter while charging with the AC Adapter.
Thanks for understanding. Please let me know if you require any clarifications
Aug 21, 2011 | Samsung SL600 Digital Camera
Does the olympus x15 charge through usb connected to the computer?
This camera charge using the charger that came with it and the USB portion of it is only for file transfer from camera to computer.
Transferring pictures from camera to computer use the usb portion of it and not for charging purpose.
May 26, 2011 | Olympus Cameras
How do u charge a kodak 7.2 camera, using the usb chord connected to the computer?
Use the USB cord to connect the camera to a powered USB port on a computer. Do not connect it through a USB hub. Be aware that not all computer USB ports put out enough current to charge the batteries.
Dec 15, 2010 | Kodak EASYSHARE M763 Digital Camera
My camera needs to be charged and i have lost the battery charger. so i put my camera on the usb cord and into the computer and tried to turn it on but it wont work.
You don't say what model camera it is, so I am going to have to do some guessing. If your battery charger normally charges the battery in the camera, then it probably will charge when connected to the computer by the USB lead. However, some cameras require the battery to be taken out and charged in an external charger. If that is the case with yours, then it probably won't charge by connecting to the computer.
It is normal for a camera connected to a computer via the USB lead to go into a kind of passive mode, just acting as an external disk drive so that files can be transferred, so not being able to turn the camera on while it is so connected might be normal. However, if you mean that you left it connected for awhile to charge up, but it wouldn't turn on after you disconnected it, then it is obvious that it cannot be charged up that way.
Oct 20, 2010 | Sanyo Cameras
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Jun 23, 2009 | Samsung L100 Digital Camera
Fuji FinePix Z100fd Digital Camera Logo
104 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
