Question about Toshiba 53H71 53 in. Rear Projection Television
Toshiba 53hx71 won't hold vertical/horizontal
I have a Toshiba 53HX71 and over time it lost vertical and horizontal hold. You can see the image but it is scrolling/rolling horz/vert. The problem is on the following inputs video 1,2,3 and ant 1, 2.
Component 1 and 2 are working great.
Also audio is working great on all inputs.
I have replaced the surface mount 10uF capacitors on the hyper board, also found a blown capacitor (330 uF 160V) on the main power board. I have replaced these and no change. Any ideas?
Also does anyone know where to download a service manual?
Thanks,
  • Anonymous Dec 30, 2008
    i have the exact same problem
premtech
  • 934 Answers
SOURCE: problem with y toshiba 53hx71
Tito,
There is a fairly common problem with those symptoms. Try removing the srs-wow board, stand-up audio board next to the tuner. If the picture clears up it's likely QD01 on the srs-wow board loading down the scl & sda lines. QD01 is an Njm1136d Toshiba p/n# 23009142.
Bill
Posted on Dec 01, 2007
  • 10 Answers
SOURCE: Capacitors for Toshiba Hyper box
Yes it will take care of numerous problems. Replace all 10mfd caps on the board.
Posted on Dec 17, 2008
SOURCE: How do I remove the screen of a Toshiba 53HX71. I
You do not remove the screen on that TV. Doing so will mess up your convergence.
Chassis must be removed by a professional.
Call the manufacturer to find you nearest authorized service center.
Posted on Mar 24, 2009
  • 60 Answers
SOURCE: Toshiba 53HX71 Projection TV
  1. If your looking for parts then call toshiba or www.partstore.com
Posted on Aug 23, 2009
SOURCE: i have a model 53HX71 toshiba tv screen is black
check for shorted horizontal output transistor and there is an open high voltage capacitor around horizontal driver.
from esg/pinoy
Posted on Aug 26, 2009
Toshiba 53hx71 blinking red light when p83 to p803 is connected
I have a 53hx71 that is haveing an issue with my blue on covergence. I have replaced both the chips and it still wont move up or down when i try to adjust manually and the auto adjust wont work either can anyone help?
Dec 08, 2013 | Toshiba 53HX71 53" Rear Projection...
My Toshiba 53HX71 takes about 20 minutes to "warm"
This is a symptom of poor solder connections inside the set. The set will continue to deteriorate until it won't turn on at all. This is essentially a labor only repair and should not be to expensive for any TV service shop. Once this has been repaired, the set should work for many years to come.
These poor connections are caused by the continual heat/cool cycles because of use and is normal.
Dan
Apr 09, 2011 | Toshiba 53HX71 53" Rear Projection...
Convergence issue Blue not convering correctly, but the other colors do. The blue is warped at the top and bottom of the screen. Is this problem something that can be fixed?
Yes,the covergence ICs and precision resistors can be replaced to rebuild the area. A reputable shop may charge around $300 . If you are technical person,I can guide you further to do yourself!
Jun 04, 2010 | Toshiba 53HX71 53" Rear Projection...
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
I have a model 53HX71 toshiba tv screen is black power button is flashing nothing will respond
from esg/pinoy
Aug 26, 2009 | Toshiba Televison & Video
Mar 24, 2009 | Televison & Video
53HX71 showing lots of green
im thinking blue lamp if whites look pink thats telling me theres not enough blue.
Dec 05, 2007 | Toshiba 53HX71 53" Rear Projection...
Problem with y toshiba 53hx71
Tito,
Bill
Dec 01, 2007 | Toshiba 53HX71 53" Rear Projection...
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
53hx71 toshiba
I had this problem and paid a repairman to fix it. He said he has seen it often in this model, and immediately repaired it. It works now. He replaced two 18 pin switching modules, about a 1/4" x 2" x 1"; and 3 "micro-caps"(fuses?). It took about 45 minutes and cost over $400.
Mar 16, 2007 | Toshiba 53HX71 53" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
