Question about Gateway M350 Notebook
Bsod during windows installation
Tried reformatingg and reloading hdd after getting various bsod with error messages like stop 0X0000007A(0xE103BC34,0XC000000E,###########) --WIN32K.SYS address BF800000 DATE STAMP 3F73195D
or another time --stop 0x0000007 (0xc03e161c,0xc000000e,########) --MountMgr.sys address f85878b2 base at F8583000.BSOD came up during reloading.Tried replacing ram didn't work. Before I reformated I ran a quick hdd test using PCDoctor -he didn't find anything.
  • 82 Answers
Try doing this as suugested, you might not need reformatting.
http://www.pcreview.co.uk/forums/thread-94921.php
Posted on Oct 22, 2008
Keeps crashing, ram slot issues
Test one DIMM at time. One slot at a time.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode). Or, you could also try uninstalling last program(s) that was installed, again in safe mode.
  • Re-install Windows.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Sep 24, 2012 | HP Pavilion P6000 Series,amd Sempron...
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
Sep 06, 2011 | Acer Extensa 4230 Notebook
I'm building an new system and get a BSOD (Attempt to reset the display driver and recover from timeout failed.)with STOP 116(hex) and a warning about atikmpag.sys. When I first load the OS (Win 7 Pro,...
make sure all the power connectors are connected to the card ,then run the ati driver cleaner,or any driver cleaner of your choice will work,then install the catalyst 11.2 and see if that works,worked for mine.
Apr 27, 2011 | Computers & Internet
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
Blue screen of death. unable to download drivers. can not get to safe mode. cannot reload orperating system disks.
First off, note down all relevant information when you see a BSOD flash across the screen. This includes the error number and friendly name from the 'bugcheck' section of the stop error (see above), and any file names specified in the 'driver information' section.
If the BSOD comes up on the screen for a split-second before the PC restarts and wipes all the useful information away, we need to change some settings within WinXP. In most cases, it should be possible to stop your PC from automatically restarting when it develops a major error, allowing you enough time to jot down the BSOD error message. If you are using WindowsXP, right click on my computer > Properties > Select the 'Advanced' tab > and under 'startup and recovery' click the 'settings' button. This will open a new window, and under the 'System Failure' heading, uncheck 'Automatically restart.' Continuing on, attempt to restart the computer normally into Windows. If the BSOD occurred while booting Windows, you may be taken to a troubleshooting menu and will have to select 'attempt to start Windows normally.' If your computer starts correctly, continue using it and store the error information for later reference. If the BSOD reoccurs at random or irregular periods, see Section D below on troubleshooting intermittent stop errors.
If your system does not start correctly or the stop message happens again, reboot the system. When the POST (memory checking) screen comes up, press F8 repeatedly. This will bring you to the Windows advanced options menu.
In the Windows advanced options menu choose 'safe mode' to attempt to boot into Windows Safe mode. Safe mode loads Windows XP with a minimal set of drivers and no automatically loaded software. If faulty software or drivers are causing your BSOD problem, safe mode should load correctly. If safe mode loads correctly, refer to Section A below on 'troubleshooting software stop messages.'
If safe mode does not load correctly, and/or you get the same stop message upon attempting safe mode, it's time to try the 'restore last known good configuration' option in the advanced options menu.
Restart your computer, pressing 'F8' again to load the advanced options menu and select 'last known good configuration (your most recent settings that worked).' This uses Windows XP's built in system restore utility to restore the most recent save point, which should be the last time you installed any drivers or other software. If your system boots normally after this operation, hopefully your problem has been fixed.
If you are still receiving a Blue Screen Of Death after the above procedures, or if system restore was disabled on your system, note down any new information on the error and start thinking. Did you install any new hardware or software just before this problem occurred? The driver information section of the BSOD may help with this.
If you did install new hardware or software, and you think you know what it might be that is causing the problem, this gives you a big boost in resolving the situation.
Otherwise, proceed to the advanced troubleshooting sections below. Chances are your error is hardware or system file based and will require more effort to repair.
Specific Repair Instructions
If you have a reoccurring Blue Screen Of Death or crashing problem, and can't use Windows effectively because of it, it's time to look at more specific methods of troubleshooting your problem. Depending on the results of the basic troubleshooting steps above, you should have a good idea of whether the problem that is causing the stop messages is related to software or drivers you have installed, or is a hardware or system file issue.
Essentially, if you can't boot into Windows XP safe mode because of crashes or Blue Screens Of Death, you likely either have a hardware error or one or more essential system files is corrupted or missing. If you can boot into Windows XP safe mode, but get constant or frequent BSOD's when running XP normally, you have a software or device driver problem.
Make sure that if you added any RAM to your computer which is a common cause for BSOD that you added the correct RAM for your computer and that it is equally distributed in the ports meaning each port for the RAM has the equal amount of RAM on each side (eg, one stick 1GB, and the other has 1GB, etc).
Jan 03, 2010 | Dell Dimension 2400 PC Desktop
Windows BSOD on all restarts, even in Safe Mode and even if I start with video in VGA mode. Stop code is 0x0000007E plus four more codes in parentheses. During Safe Mode restart the last file to appear on...
7E is a memory issue or general driver fault. It's windows way of saying "i dunno it just died". If you have Dell diagnostics, run a full system check, to ensure the hardware is ok. If you get no errors, then you have a driver fault in windows. This is From Microsoft:
If the following conditions are true, the issue might be a hardware incompatibility with Windows XP because all the installed drivers are Windows XP drivers:
  • You receive the STOP 0x7E error when you first start the computer.
  • You receive the STOP 0x7E error after you run the Setup program.
  • You did not install any third-party drivers during the installation of Windows.
However, if you receive the STOP 0x7E error after you upgrade from Windows 2000 Professional, or if you recently added a new hardware device, this issue might be an incompatible driver or an incompatible hardware device.
Basically, the 7E error is a defective driver. You will likely have to get your computer recovered by a professional shop, or if you have nothing important on it, attempt to reformat and reinstall. It is unfair that Windows has borked your computer and they wont fix it. I hope I was able to at least point you in the right direction.
Oct 26, 2009 | Dell Inspiron 700M Notebook
Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Please try changing the HDD. If same thing happens the problem may be with ur O/s Cd or the Mother board
Please let me know this is used machine or New one. If new one please take a different O/S cd and install it.
If you are installing XP and your HDD is SATA then you need sata drivers.
Mar 07, 2008 | Toshiba Satellite 1905-S301 Notebook
Crashing during Windows Setup
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
Sep 17, 2006 | Microsoft Windows XP Professional for PC
Gateway M350 Notebook Logo
241 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
