Question about Compaq Armada 7400 Series Replacement 204278-001 Keyboard
Key board how do i remove the keyboard... I need to get to the HDD
    President:
  • 1,901 Answers
You don't remove the keyboard to remove the HDD. It is accessed on the edge of the left side of the unit.
Here is a link to a pdf file showing how to do it:
Armada HDD Replacement
Posted on Oct 22, 2008
Dissembling YDP- 131/YDP-213 keyboard to reveal key contacts?
To remove keys you need to remove screws on the top row of the keys, turn over, remove circuit boards that run the length of the keyboard, remove rubber contacts. Keys will then un-clip the circuit boards hold the keys in place.
If you need more info admin@beckettsmusic.co.uk
Oct 17, 2016 | Music
Select boot device Error after keyboard spill Wierd results
It is more than likely the motherboard has been compromised, you will see white spotted area's where the liquid has spilt. I have fixed a few boards using a stiff toothbrush and rubbing alcohol, but to be successfull this needs to done quickly. If you are able to clean everything off and it seems to work check out www.ebay.com Type make and model, refine search to keyboard.
Jun 26, 2012 | ASUS Computers & Internet
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
I forget the hdd password
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 15, 2011 | Computers & Internet
"Diagnostic Boot Selected" problem on power-up boot
its the problem with the keyboard. make sure Function key is not pressed while turning on the computer. normally it happens only then. if the problem presists try reseat the keybaord. to see how to reseat the keyboard.
NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries.
NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer.
  1. Remove the hard drive.
  2. Turn the computer over, and remove the five M2.5 x 12-mm screws labeled "circle K."
  3. Turn the computer over and open the display.
NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Be careful when removing and handling the keyboard.
  1. Remove the center control cover:
  2. Insert a small, flat-blade screwdriver or plastic scribe into the notch at the right end of the center control cover and pry up the cover.
  3. Lift the center control cover up and away from the bottom case.
  4. To release the keyboard from the palm rest, use a small, flat-blade screwdriver or plastic scribe to pry up the right edge of the keyboard near the blank key.
  5. Lift the keyboard straight up about an inch and then rotate it forward toward the front of the computer, until the key face is resting on the palm rest.
NOTICE: Do not pull on the keyboard flex and track stick cables.
Pull up on the keyboard connector to disconnect it from the keyboard interface connector on the system board.
Remove the keyboard from the bottom case
See the images below for ready refference
To repalce the HDD see the image below
I am sure this will fix the computer. Because in this you are reseating the HDD as well. all the best.
Oct 14, 2009 | Dell Latitude C640 Notebook
CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Mar 18, 2009 | EliteGroup ECS DESKNOTE A929 Notebook
Dell Wireless Keyboard
THE KB BOARD NEEDS TO BE SERVICED, BY REMOVING THE SCREWS OR SNAP CLIPS THAT HOLD THE KB TOGETHER, CLEAN THE CURCIUT BOARD OR PLASTIC FILM WITH SOME ACOLAHOL AND LENT FREE TOWEL,
USE A CAN OF COMPRESSED AIR TO REMOVE THE DIRT FROM THE KEY SWITCHS.
PUT IT BACK TOGETHER,
GO INGO CONTROL PANEL OPEN DEVICE MANAGER, GO DOWN TO KEYBOARD AND CHECK FOR ANY TYPE OF UPDATES OR AND CHANGES TO THE PROGRAM.
IF YOU CAN FIND THE KEYBOARD TEST THAN TEST THE KEYBOARD TO MAKE SURE ALL KEYS ARE WORKING PROPERLY.
RODGANDYSR
Mar 07, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
Keyboard problems
dear bangaloreboy , this may be due to your shift key is having a problem. This is permanently pressed or the other key is having some problem . If you think shift key is not causing a problem please check the key board settings from contol pannel .
I donot think this is caused by changing the operating system.
Best Regards
rafique
Feb 25, 2008 | Computers & Internet
Compaq Armada 7400 Series Replacement 204278-001 Keyboard Logo
125 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
