Question about Pioneer AVH-P5700DVD Car DVD Player
Help brihtness on my avh p5700dvd
I would like to kno how to put up the brightness in ma screen cuss it's really darck n i can bearly see the info on it
Hold down the nav button on the far right, it will bring up the screen adjustments, adjust as needed.
Posted on Oct 24, 2008
The LCD screen on my avh-6600dvd is not lighting up when I use it its really dim
Almost the correct model. I would check the backlight is working correctly. Possible broken flexible cable.
Dec 11, 2015 | Pioneer AVH-P5700DVD Car DVD Player
My Pioneer AVH-P5700DVD's screen is very dimmed i can bearly see the buttons, it seems like there is no brightness in the screen please help... I checked everything already... Maybe is a dim adjustment?
it could be a dim adjustment. did you hook up the dimmer wire to the factory harness if so and your dash lights are low then thats the issue. if not then check the brightness on the unit. if that is not lowered then the internal lights inside the unit have started to burnout. if thats the case uninstall it and send it in for repairs
Nov 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I have a AVH-P5700DVD and the screen is off on calibration, if I hit the play button, it actually hits the button to the right. Does this stereo have a way to calibrate it or is it possible that it is...
In order to calibrate the AVH-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
Aug 11, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
May 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
I have a avh p5700dvd and when i put a cd in it reads error 02
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
Nov 06, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Avh-p5700dvd touch screen
Go to: http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF This manual will give you everything you need for your Pioneer unit.
Nov 25, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-P5700DVD Car DVD Player Logo
137 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
