Question about Lexmark Office Equipment & Supplies
Printer goes through printing motion but nothing prints on paper
  • 168 Answers
SOURCE: epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Posted on Feb 09, 2008
yooperbud
  • 8637 Answers
SOURCE: Printer dock won't print. Says ''no Paper,'' but is full
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
dagr81
  • 59 Answers
SOURCE: printer will not print to paper, I put in new cartridges, etc
just put in RMA
Posted on Apr 04, 2009
aicaxz
  • 511 Answers
SOURCE: Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
Posted on Jun 01, 2009
SOURCE: new installation of kodakesp3 printer will not print
try device manader and go to the propertys and reset to factory settings.as origional
- this finely let me copy from my printer
Posted on Jul 31, 2009
My printer will not print. it goes thru the motion but nothing prints
The ink-jets that spray the ink onto the paper may be clogged; run a few "print-head-cleaning" cycles. Also, check that you've not run out of ink.
Feb 26, 2011 | Dell V313w AllInOne InkJet Printer
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Printing is blank...no ink coming out on to paper
Your printer cartiage will be out of ink.
Or it will be dry cause of not used from long time.
Change the printer cartiage may fix this problem.
Thanks.
Oct 09, 2009 | Office Equipment & Supplies
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer not printing
Try this. Push the copy and cancel buttons together for about 3 seconds. Then release. The printer should push a blank piece of paper through. Try to print.
Jul 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing
Time for new printer, Printhead is clogged solid. Printhead is more expensive than the cost of a new printer.
Feb 13, 2008 | Epson Stylus Color 660 InkJet Printer
Nothing printed when paper goes through printer
the ink nozzles on the cartridges are clogged. first try cleaning them using a alcohol-soaked Q-tip against the shiny part where ink comes out (remove cartridges first). if still no ink, cartridges may be out of ink, so either replace or re-fill them.
Oct 28, 2007 | Lexmark Z600 InkJet Printer
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
