Question about Fuji FinePix A101 Digital Camera
Lens problem i can not see anything on the lcd screen when taking a picture. i can see previous photos taken when i scroll through the display. the lens cover does open when the camera is turned on. flash works. but no photo when shutter is pressed. please help asap. my son's 1st birthday is in 1 week and i can not afford a new camera!!!
    Top Expert:
  • Fuji Master
  • 83,843 Answers
You might as well replace the camera in this case.
Posted on Nov 23, 2017
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Fuji FinePix S5000
This appears to be loose connector to the motherboatd from the screen.
Try gentle squeezing of the casing near the bottom of the body
This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
Posted on Dec 13, 2007
SOURCE: White Screen
some say that with problem, the ccd imager must be replace?...
Posted on Feb 26, 2008
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
Posted on Sep 11, 2008
SOURCE: Camera is acting as though there is a lens cap
yours is a broken CCD-chip - like ours.
hardly any good-used for the F700/710/810 avail anywhere
another new (used) camera is my best advice - repairing a busted CCD aint worth your time / money / efforts.
Posted on Dec 26, 2010
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
I cannot see anything when in camera, film, or view mode. When I snap a photo, it sounds like a picture was taken and the flash still goes off, but nothing is displayed on the screen. Only when I attempted...
Does it show pictures on the computer or is it black images, if they are black, your cameras lens cover could be stuck, it opens up when the lens is fully open, dirt-sand and dust or old grease causes the problem. otherwise your LCD on the camera could be off by mistake, (Do a camera reset) or a bad LCD
Oct 27, 2009 | Canon PowerShot SD600 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
LCD display isn't on
In order to turn on Live View, first put the camera in one of the Creative Zone modes (i.e. P, Tv, Av, M or A-DEP). Then press the menu button, and scroll to the second settings menu (the second wrench-symbol), then scroll down to "Live View function settings" and press the SET-button. Then scroll to "Live view shoot", press SET, scroll to "Enable", and press set again. Close the menu by pressing the menu button twice.
Now you can turn on and off the live view on the LCD by pressing the SET-button.
/Chris
Jan 04, 2009 | Canon Digital Rebel / EOS-300D Digital...
Problem with lcd monitor
in the rear side display mode switch is there. you just press the switch once or twice.you can able to see live images
Apr 28, 2008 | Canon PowerShot A460 Digital Camera
LCD Display
If you mean you see no picture on the lcd monitor before you take the picture and see it only after you have taken it than this is normal with digital SLRs. But if you mean you see nothing on the lcd monitor after you have taken a picture ( no playback ) then either the shutter is not working , or the CMOS sensor is not working or the camera is not communicating with CF card.
Sep 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Fuji FinePix A101 Digital Camera Logo
54 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
