Question about Epson Stylus CX7800 All-In-One InkJet Printer
Scanning trouble PLEASE HELP!!!
The scanner light works and it moves. When the page prints, only approx. 1/4" on one side appears. The rest of the page looks like static on a television with colored streaks in it. We have installed it again and tried everything we know. Can you help.
I'm having the same issue - static appears in place of the scanned image. The white areas show where the scanner correctly pics up the image.
  • jman2007 Oct 31, 2008
    I made a copy directly from the printer and had the same problem.
    Problem Solver:
I've done all the above and still the same problem.
Someone has to solve?
Grateful.
Werner
Posted on Feb 08, 2009
  • Epson Master
  • 19,396 Answers
Try first reinstalling the scanner drivers, just to ensure it is not a controller problem.
If reinstalling drivers does not fix it, then it is either a lose connector/bad wiring inside the scanner.
Or a fault, like faulty scanner pcb, fauslty sensor, faulty scanner engines.
In both case the scanner must be taken apart and tested by a technician.
If you live in US you can call (800)922-8911 [ press 1 then 2 ] to get support.
If you live in a different country, use the Epson website to get support:
Posted on Oct 31, 2008
  • Ginko
    Ginko Nov 01, 2008
    If you get same problem even doing a copy , then it is definitively the scanner CCD array. That is the sensor that take a snapshot of the picture sliding on the document (see here to find out how it works).
    To fisx this the scanner must be taken apart, and the array replaced.
    Some times the array is fine, and you need to replace or put back in place the flat cable connectors that connects to the array.
    This job should be performed by a techincian.
    Brigadier General:
  • 6,966 Answers
I am afraid that the scanner engine of the Epson CX7800 has sustained a hardware damage. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
If you are considering a DIY, pls re-evaluate the cost of repair and the downtime including sourcing of parts. It may be to your advantage to simply replace the unit or request warranty repair/replacement (if still under warranty).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
  • Louie  Role
    Louie Role Oct 31, 2008
    As initially suggested, it is a hardware problem, the scanner engine.
    Sergeant:
    Champion:
  • 435 Answers
Does this happen only while scanning?
How does it work when you print some file from computer?
Please let us know so that we can focus on one of them...
I think you might have did this... Did you try uninstalling and reinstalling the printer/ scanner driver ?
They printer hardware look to be fine...
Did you try scanning to the computer ?
How does the picture look like? same as the one above ?
    Sergeant:
    Champion:
  • 331 Answers
I wanted t know if the scanner which u r talking about worked correctly
before it had this problem ...........
if yes then there will be no problem with the drivers....
the problem could be either with ur printer
or
with the optical sensors ....
the light getting on or off does not mean that ur sensors are correct ....
try replacing the sensors with some other sensor and see if it is working or not and pls tell if it worked
till hen could u give the Scanners company and model no.
    Genius:
  • 1,226 Answers
Disconnect the scanner and then rest it for a couple of minutes then uninstall the driver and reboot the computer and then reinstall the drivers. note sometime scanner got error due to antivirus activity.
may this help,
melnavz
    Genius:
  • 2,035 Answers
First try to make a copy from the printer if the copy is fine then there is the problem with drivers , if the copy is blurred or as the same problem then its a hardware problem in the printer ,if the copy is fine then you need to install the lastest drivers from this website install scan drivers :
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58773&prodoid=56291070&infoType=Downloads&platform=All
Good luck...
Allignment page will not print correctly
Print heads alignment completes after scanning fully printed align page. In this case all colors are not printing due to cartridges faulty.. You need to replace both cartridges at a time to this types of errors..
Jan 05, 2013 | HP PSC 750 All-In-One InkJet Printer
I have replaced the imaging unit and it still asks for a new one how do i reset it
folow the steps please:
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
May 19, 2011 | Samsung CLX-3175FN Printer
After clearing a paper jam when you print the right side of the printed paper is not as dark as the rest of the page. I have replaced the fuser to no avail is there an adjustment that needs to be made?
Hi there! Wich color is not dark as the rest?Only when you print in black and white or even in the color printing? If the black or any of the colors are not dark as the rest of the page you must clean the led scanners(Wehn you open the top cover you will see long black boxes on the top cover,those are the led scanners) if they are clean then your transfer belt is damaged and can`t transfer the image from the drums to the paper.You can check the belt by starting a printing and open the top cover while the paper is moving under the toner cartridges and look at the page!Please replay what you have seen so i can help you futher!Thaky for usin Fixya.
Nov 29, 2010 | OKI C5200n Laser Printer
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
thanks
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP PSC 1510 Scanner - Left side print is black (un-scanned)
Uninstall and reinstall the scanner utilities. Also make sure antivirus is disabled.
Thanks
Jan 25, 2009 | HP PSC 1510 All-In-One InkJet Printer
1. does scanning from the pc looks good ?
2. printing photos from the pc looks good ?
3. does standalone copy (placing image on the scanner bed then pressing the COPY button on the printer) looks good ?
Dec 31, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Copy mode
Is this happening when you print or when you scan? If when scaning you could have something on the scanner bed... If this is happening when you print, it could be the cartride is defective.
Jul 06, 2007 | HP Photosmart 2575 All-In-One InkJet...
Test page and scanner
Hey satz, Take that test page, and put it into scanner, (Printed area will be on mirror side) then press scan button "Bottom left side of your printer". After stopping the fluctuation of light you will never face that problem. This error appears when you turn out the cartridge from your printer. sanjeev manglamenterprises@hotmail.com
Apr 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
100 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
