Question about Philips VOX120 Wireless Headset
Pin number for philips SHB6100 aside from 0000.
I tried using pin number 0000 to pair my Philips SHB6102 with my phone.  The bluetooth headset does not recognize the number 0000. Is there any other pin number?
  • 4 more comments
  • Anonymous Oct 23, 2008
    I have a same problem, please help as
  • gazwalley Nov 16, 2008
    trying to pair motorola rokr e8 to phllips headphones and passkey 0000 doesnt work
  • Anonymous Nov 22, 2008
    Philipa SHB6100 isn't pairing with my blackberry or the most typical code (0000) doesn't work.
    Shucks.
    other pin number?
  • Anonymous Nov 24, 2008
    0000 does not work
  • bob_y_zh Jan 23, 2009
    Yes. I have the same problems too. But the manual says it should be 0000. is there anyway to reset the pin?
Yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Posted on Nov 27, 2008
  • ricardob_tm
    ricardob_tm May 22, 2012
    Thank you!! It has helped me with my headphone Pillips sb6110 and my Samsung Galaxy SII, really helpful!
  • Denis Jun 17, 2012
    Wow! Thank you very much. You're saviour, really. It works, it works. I was several years in a real hell with my Philips, not knowing, what to do else with it, yeah. Several years! Thanks, gazwalley. Now I'm free!
Yes.
1. Turn your headphones off
2. Press multifunction key until the led flashes red/green
3. Pair your phone, 0000 should now work.
Posted on Feb 04, 2009
Have u tried to hold down the play/phone button when u turn it on untill it flash red/green and the try to pair it? or have u tried the passkey 1234?
Posted on Nov 26, 2008
Yup it worked for me thanks for the help cheers
Posted on Oct 06, 2009
Thnx ..it works....it starts working after red/green light flashes..:)
Posted on Nov 04, 2010
Motopure H12: I don't know my pin for pairing?
Motorola Default unchangeable pin is 0000
https://motorola-global-eng.custhelp.com/app/answers/detail/a_id/12462/~/pairing-pin-code
Jan 17, 2013 | Motorola Mobility Motopure H12 Bluetooth...
How do I pair my bluetooth to my blackberrycurve. How do I pair them together?
1) check that the bluetooth is 'on, in settings on your blackberry
2) on the headset click and hold the button, which should turn it on, then keep holding till the light flashes or goes solid to show that it is in 'pairing mode'.
3) on the blackberry select the headset which will now appear in the bluetooth list
4) you will need to enter the pin code, which as default is usually: 0000 or 1234 or 12345
Thumps Up Please!
May 06, 2011 | Philips Cell Phones
Need pin code
Bluetooth pin numbers can be any four digit number you like as long as you input the same four digit number into both the headset and the phone ie 1234 or 0000 when you are pairing them together
Apr 28, 2011 | Samsung HKT450 Bluetooth Headset
Motorola h715 bluetooth pin number
Try '0000' (four zeros), which is the code chosen by the vast majority of bluetooth devices' manufactures.
I was able to find the user guide for the H710 headset, but unfortunately not for the H715. It's here, anyway. Hope you find it useful, somehow.
Cheers! Carlos
Apr 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
Pin code
Is this the first time you are pairing two Bletooth devices ? Is the security pin for your Samsung phone '0000' ? Usually, the code you have to enter on your phone to pair it with a Bluetooth headset or headphones is '0000' (the number 'zero' 4 times), unless Jensen's Bluetooth headphones use a different pin.
Hope this helps.
zeceten@yahoo.com
Dec 22, 2007 | Audiovox WBT212 Headphones
Philips VOX120 Wireless Headset Logo
5,247 people viewed this question
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
Dayton Computer
Dayton Computer
kiranbodapothula
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
