Question about Dell Inspiron 6000 Notebook
Screen does not work
Whe I turn my computer on the screen starts it's initial pictures but then blinks off. My sounds still works so I can here that the computer is starting correctly just cannot see anything. Also, the little suitcase icon with the "9" is on from initial start until I turn it off. What can I do?
Thanks!
  • nahla Jan 23, 2009
    dell inspiron 6000 laptop problem. i cannot access any programs and my screen just blinks. i have tried safe mode and nothing works. help
  • Dell Master
  • 998 Answers
Did you try to start in safe mode? Turn on the laptop and start tapping the <F8> key. This will bring you to a menu with different options and select ‘Safe mode”. If that doesn’t work, try connecting an external monitor to the laptop. You may have to select the video output to display on the external monitor by holding down the blue <FN> key and pressing the blue CRT/LCD (located on one of the <F> keys, like F8,F9, etc..).
If the laptop display works in safe mode, then you probably have a video software driver problem.
If the display works on the external monitor in normal mode, then you probably have a problem with either your LCD panel.
Hope this helps.
By the way, the "9" led with the pad lock means your "Num Lock" is enabled.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 22, 2008
Samsung UN46D6400UFXZA Version H302 tv has sound but no picture. Screen lights up initially with some horizontal lines then it just lights up (backlights on) but no picture.
Try removing and replacing the LVDS cable that goes from the main to tcon board along with the flat connectors that go to the panel and see if that helps, if it doesn't chances are you have a bad Tcon board
Oct 25, 2017 | Samsung Televison & Video
Samsung ln22a450 red light indicator blinking 5 times also sound like initial screen but no picture no audio after that. 10 min later the tv it shut off by it self
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 02, 2014 | Televison & Video
My computer screen goes black whe i turn it on
It would be helpful if you posted the Make, Model and the OS you are using. Does it boot? Can you boot to Safe Mode? Have you checked ALL cables? Do you get anything on the screen? Fans spin? LED's Blink at boot? Sound? Need more info.
Mar 13, 2013 | Computers & Internet
When i turn the laptop on all i get is a blank screen with the mouse arrow nothing else.
When you turn it on, does it initially show a "splash" screen (a picture) ?
Does it initially show any information, such as the amount of RAM installed,
or any "press <blah> to enter SETUP" message?
If not, then the motherboard has a problem.
If it does display the above, then it will try to load Windows from your disk-drive.
If the disk-drive is not connected, or it has "died", then Windows cannot be loaded,
and all you'll see is a blinking white "underscore".
If Windows does start to load, and you see the mouse-arrow pointer, then Windows is loading, at least partially.
Take your computer to a qualified technician at a computer-store, for thorough trouble-shooting & repair.
Feb 12, 2011 | Compaq Presario 700 470024-192 Notebook
Initial poor picture quality
how old is the moniter as it sounds like either dirty connections or the pixels are getting a bit tired
Jul 04, 2010 | Compaq 17" Flat Screen CRT Monitor
When I turn the computer on the screen doesn't work
This is the monitor not being attached to the Graphics Card properly.
Sep 14, 2009 | Toshiba Satellite M45-S331 Notebook
Picture and sounds turns off and on by itself
1. Initialize settings by pressing "menu, 1, 2, 3, enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the tuner settings
Mar 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Dell Inspiron 6000 Notebook Logo
289 people viewed this question
Alun Cox
