Hoover AI130 Front Load Washer
Problem for Hoover AI130 Front Load Washer
Washer won't fast spin or drain
By quattro on Jul 28, 2006
I do apologise because my product is Hoover Quattro 1100 front loader washer AS110.My washer does the usual cycle but will NOT fast spin/drain,and because of this the door won't open due to the water in the tub,so I have to open the door manually?.Please advise/help.
Thankyou
Gurdial
Best Solution
posted on Sep 04, 2007
Very Helpful)
dovi
Rank: Guru
Rating: 88%, 2506 votes
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump.
To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port.
Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Apr 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the pump requires changing All of £23 clear any obstructions like bra wires etc in the main discharge hose (the big one) from the drum to pump
Popular Solutions for Hoover AI130 Front Load Washer
Questions and Unsolved Problems for Hoover AI130 Front Load Washer
Do you recommend Hoover AI130 Front Load Washer?
Answer
Answer
The belt came off (not snapped or frayed) but will not stay on when i spin the drum it wiggles off.
Answer
the machine keeps stopping wit error code 2 aod 4 and once 3 a lot of time but not all the time also... (More)
Answer
The delay timer leds flash at any point in the program. they flash 11 times pause then 11 times... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , AK
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
