Question about Roper RAS6233KQ Top Load Washer
Will not spin fast, when it spins you can rase lidmby pass door switch and stop itfrom spinning
Washer will not spin fast enough. You can raise the lid by pass the door switch and stop the tub from spinning with your hand I checked drive couple is ok. Motor does not stop when you stop the tub. help!
    Brigadier General:
  • 6,966 Answers
Based on your post, strongly possible that the belt is slipping. In some versions, there is an adjustable tensioner to enable tightening of the spin belt but it would only go so much. Correct procedure then would be for a replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
    Genius:
  • 2,035 Answers
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Posted on Oct 22, 2008
    My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
    Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
    If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
    Mar 06, 2015 | Maytag Washing Machines
    Spin cycle does not remove excess water (worked great till recently)
    EITHER A LOOSE WORN OR BROKEN BELT, A LOOSE SLIPPING CLUTCH A BAD DOOR SWITCH
    Apr 09, 2014 | Frigidaire GLTF2940ES Front Load Washer
    My kenmour washer stopped spinning
    Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
    The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
    One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
    The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
    I hope this helps.
    Shane
    Mar 26, 2011 | Kenmore Washing Machines
    No spin cycle
    I hope this helps.
    Shane
    Shane
    Mar 01, 2011 | Hotpoint WMA76 Front Load Washer
    Wont spin. just makes loud noise.
    I hope this helps.
    Shane
    Feb 26, 2011 | Kenmore 22422 Top Load Washer
    Wont spin
    I hope this helps.
    Please reply with additional details for further assistance.
    Shane
    Feb 12, 2011 | Kenmore 98702 Stacked Washer/Dryer
    Spin does has stopped working. all the functions work normally but the washer has stopped spinning.
    The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Here is a link to the part you will need.
    Jan 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    Kenmore 90 Series washer needs two spins to remove water
    We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
    Dec 29, 2008 | Washing Machines
    GE wpse4200aoww washer won't stay in spin mode
    Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
    Aug 23, 2008 | GE WHRE5260E Top Load Washer
    Front load Frigidaire Gallery washer
    You are having a door switch problem change it out and you will have a new washing machine.
    Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
    Roper RAS6233KQ Top Load Washer Logo
    57 people viewed this question
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike Cairns
    Mike Cairns
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
