Question about Nikon Cameras
I have just recently boughta Nikon D60 and currently own a Tamron 28-300 lens and a 90 macro lens. I think that I want to buy a strob after a workshop I went to this past weekend. I want to be able to hold the flash off the camera and use it to high light some macro shots. I don't know whether to but the Nikon SB 600 or spent the $100 difference and buy the SB 800? Or am I bitting off more then I can chew at this stage of the game and getting into equipment that will be complex and frustrating to use??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The SB-600 will probably do everything you want.
One caution: To use flash off your D60 you're going to need either an external sync cord or a wireless controller. The SB-800 (and the current SB-900) can be used as a controller, the SB-600 can't. But the controller goes on the camera, so you'll end up needing two flashes.
Posted on Dec 30, 2009
I have just purchased a Tamron 35-70 3.5 CF MACRO BBar MC Nikon fit lens. Are there any special settings/requirements when using the lens for macro photography. Thanks.
This is a macro lens, and I can't find it has an auto focus nor can I find if it has a chip, or even any electrical connection. The sharpness though should be good.
When you are using a non chip lens on a Nikon, you only can use it in manual. So you have to put the main dial to M. Then you have to focus manual and just take a shot. the result will be to dark or to light, unless you already knew hoe much light you have and dialled the aperture and shutter time in correct.
For macro you want a large aperture number, to have as much sharpness (large depth of field) so the best thing is to choose f 8 or 11 and turn down the speed till you have a good light picture.
I found a forum about this lens, but they did not say a thing about the specs.
Tamron Adaptall 2 35 70mm F3 5 CF Macro 17A
Check some results here:
Tamron 35 70mm 3 5 17A on the GH2
Jan 23, 2015 | Nikon Cameras
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Sep 18, 2011 | Cameras
28-200mm F/3.8-5.6 LD Aspherical autofocus does this lens fit Canon 40 d?
Tamron makes their lenses available with a variety of mounts. A lens with a Canon mount will fit Canon cameras but not Nikon cameras. A lens with a Nikon mount will fit Nikon cameras but not Canon cameras. As long as you buy a lens with a Canon mount, you shouldn't have any problems.
Jul 04, 2010 | Tamron 28-200mm f/3.8-5.6 LD Aspherical IF...
Autofocus stops after heavy usage
Maybe cleaning the gold coloured contacts on the back of the lens and the ones in the camera may help. Worth a try!
May 12, 2010 | Tamron 18-200mm f/3.5-6.3 for Nikon
Tamron Macro 90mm lens r07 error on Nikon D70S - any ideas how to fix?
Having gone over threee months without a response, I assume this is no longer a problem.
Apr 11, 2010 | Tamron Macro 90mm f/2.5 Manual Focus...
Problem with Tamron 18-270mm VC Lens
Do note that all lenses have a minimum focusing distance. The way you describe it is it seems that you are taking close-up shots (also called macro) of small items like flowers or insects.
For some long lenses, the minimum focus distance is as far as 1m or more. Check your lens documentation to find out what this is for your lens.
My recommendation for you if you still want to use your current lens for macro photography is to get "extension tubes". There are a number of brands but any brand will do (e.g. Triplus). Just make sure to mention that you will use it on a Nikon mount to make sure that you get one that will fit. Better yet, bring your setup to the cam vendor when you buy the tubes. These tubes are just extension rings without any glass and will allow you to take close up pics. Good luck
Nov 30, 2009 | Cannon EOS 50D Digital Camera
My Nikon D60 fell and the lens came off. Now the lens no longer holds -- it appears that a piece of plastic has chipped which prevents the lens to click close. Where do you recommend I get it fixed. I...
If you are no longer covered by an in-store warranty, whether an extended service or recent sale (typically 30 days) type, going back to Best Buy probably will not help (but asking about it can't hurt).
Nikon Customer Support may be the best place to get the camera repaired, but you'll have to determine if the cost is worth it. If you decide to buy new, be aware that not all Nikon lenses work with all Nikon cameras. Otherwise, if you buy a new Nikon, you'll be able to reuse many of the accessories you currently own for the D60. This can save you a fair amount of money - but make sure your lenses and other accessories will work with the new Nikon model you're planning on buying *first*
Contact Nikon Service for more help with your D60 below:
http://imaging.nikon.com/products/imaging/support/index.htm
I hope this helps!
Oct 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Cameras Logo
94 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
