Question about Hitachi 53UDX10B 53" Rear Projection Television
Tv comes on after being turned off.
Relays on power supply board sticking . Is this a common problem ? Is there a repair kit ?
  • 2 more comments
  • 66542 Oct 22, 2008
    My Hitachi 51UWX20B turns on by itself also. It can be turned off in the evening and 1 or 2 times a week it will be on the next morning. Its been doing this for several years. I'm just used to it.
  • cddad1960 Oct 23, 2008
    Yes relays are sticking . power light will stay on some times ,but picture goes out with remote . Some times both go off. wake up in middle of night and TV will be on . IR sensor is working because all controls work with remote, except the power will not stay off. Im looking for a repair kit and if any service bulletin issued by Hitachi for this problem .
  • jason May 11, 2010
    or it just may need new solder
    are you sure that they are sticking? because it wouldn't shut off if it were stuck
    are you sure its not the IR sensor? or the crystal?
  • 905 Answers
It probably just needs some soldering then , when we get these in most of the time it needs new solder because after the set has been running the set heats up thus causing the solder joints to crack and not connect well , and the problem only gets worse as more components solder connection also start to crack and not make very good contact , this usually happens in the tuner solder joints and other components that create heat , so it will need to be looked at to find the bad solder . rca gave us a kit to fix some of the problems that happened , and it was a better solder with a paste that made a better hold on the heated components and connections
hope this helps
electech
Posted on Oct 23, 2008
  • 1 more comment
  • jason Oct 23, 2008
    also if you move the tuner a little bit and the tv shuts off then there is a bad conection there , but otherwise lleaving it plugged in like that condition will make something else burn out and cause more problems , it should get a resolder imediately!
    hope this helps
    electech
    also there could be a Short circuit on 24v line
  • jason Oct 24, 2008
    also change all electrolitic capacitors on the power oscillator circut and check them all over the board , check zener diodes( regulators)also
Won't turn ON. Found F601 fuse blown on power supply/inverter board. What's the most likely culprit?
Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2
www.shopjimmy.com/emerson-a17f1mpw-power-supply-co...
ShopJimmy
$19.94 - ‎In stock
This Emerson BA17F1F0102 Power Supply Repair Kit LC320EM2 ... board. If the TVhas no power it is most likely because of a blown fuse and failure of other preceding components. ... I tested F601, Q600, R602, 608 and 611, and found them to be bad. ...Power Supply / Inverter Board - Joseph A. on March 4th, 2015.
Common TV Repair for Emerson, Sylvania, Philips ...
? 5:35
https://www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
... LCD TV repairs for Emerson, Sylvania, Philips, Magnavox,blowing fuses "no power" i recommend a TV service LCD repair kit at ... powersupply power-supply "power supply" powerboard "power board" part2 part 2 pt2 ...
What Causes a Blown Fuse in TV Sylvania LCD - YouTube
? 15:31
https://www.youtube.com/watch?v=4P_0aLDZgBY
Jan 01, 2016 | Televison & Video
My Sharp Aquos TV will not turn on...just a green ligth flashing...something to do with power...how can i fix it?
The most common issue on these is the power supply boards. Bad capacitors on these boards are the issue and there are repair kits available if yur qualified for the repair other wise you can get new boards and swap them out. This is the most common issue in the business right now. Sharp sets are a little different in ther design on the power supplies but parts can be had and repairs can be made. You will need to balance the price for the repair vs a new set. Just Google TV power supply repair kits for Sharp Aquos and you will find repair kits and information on the power supplies.
If this was helpful a vote on the thumbs up would be greatly appreciated for the free advice.
Aug 22, 2011 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
Samsung lcd has no power, the red power light doesn't even come on. Could this be a fuse? Power supply board? If so, where are the fuses located?
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Jun 06, 2011 | Samsung LN32A330 32 in. LCD TV
SONY LCD MODEL KDL-46v4000 blinks 6 times before shutting down. Please note that Main power supply board and digital board have been changed, but problem persists ! Would be grateful if you can guve some...
Apr 27, 2011 | Sony Bravia KDL46V4000 46 in. LCD TV
Power light blinks 2 times, TV doesn't turn on. I read that it was power board but not sure which one that is or how to test the transistors.
This is a common problem an a failry easy DIY fix.
Mar 29, 2011 | Panasonic Viera TH-46PZ85U Plasma TV
LG 42inch LCD tv,Problem first started when on standby i try to power on and it was taking its time,getting longer and longer,Finally after watching the tv for a long period i put to standby,The next day I...
The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 22, 2011 | LG 42LC2D 42 in. LCD HDTV
When i inplug my lg 50pk750 plasma to power sorce turn on and before show the picture it turn off.
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at bigthings09@gmail.com if you have any question.and watch the video:
http://www.viewbix.com/v/LG-Repair-KIT-now-available-on-Ebay/8ec4bea5-1d91-4d23-8180-7e5214e6c8f6
Dec 26, 2010 | LG 50PK750 50 in. Plasma HDTV
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
