Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Laars lite II Pool and spa Heater LG model
Pilot is on but the burner will not light?
  • Anonymous Dec 29, 2008
    my pilot frequently goes out but when it is lit, sometimes the burner will not come on even though the water temperature is 20 degrees below setpoint. I have tried turning the setpoint to max and verified the pool pumps were on. Nothing. However, when the pilot is out and I have to relight it, the heater lights as expected?
Bad pilot generator? Flow issue?
Posted on May 25, 2009
30000 litre pool keeps going greener and greener. the more chlorine I put in the more greener it goes
you also must have a working pump with good flow.check pH first then balance the rest of the chemicals,
Jan 11, 2017 | Pool & Spa
Tip
Automatic pool cover failures
Most automatic pool cover failures begin from too much drag on the system. Changing the six pulleys and cleaning out the box is a cheap way to get the most years from your cover.
on May 04, 2014 | Pool & Spa
Can you leave an automatic pool cleaner in permanently
Not a good idea, unless it is a self-contained or using a separate pump, even then only run it when it's needed.The kind that use the pools circulation pump should only be used when needed. pool screened in ? use the cleaner 2 times a month for a few hours,
running a creepy crawler every time the pump comes on restricting the flow DRASTICLY reducing flow and will cause chemical imbalances eventually destroying the pools finish.-pump -filter ...
Jan 07, 2017 | Pool & Spa
How many gallons of water in a 4'by 24' round pool?
the volume of the tank is calculated by the formula
22/7 x 24 x 4
= 301.7143 cubic feet
1 cubic foot = 7.48052 US Gallons
therefore your tank will hold 2257 US gallons approximately
Mar 04, 2015 | Pool & Spa
Cal spa not running
Which fuse is it? Fuses protect the board from getting fried when something goes out on your spa. Which fuse is it? Usually when I hear a fuse has been blown, I start looking at the pump motors, or ozonator etc. You might go through some fuses but unplug all the spa accessories from the pack and re insert one at a time until the one you plug in blows the fuse. That will be one that has the problem. Let me know what you find.
Mar 28, 2014 | Pool & Spa
Salt water swimming pool
what is the actual size of the pool, and do you have a chlorine generator to use the salt? if so consult the generator mfgrs site for correct saturation of salt.
May 17, 2013 | Pool & Spa
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
576 people viewed this question
Top Teledyne Laars Pool & Spa Experts
paulcarew
Jay Finke
Jay Finke
Brandon Berry
Brandon Berry
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
