Question about Dishwashers
Vulcan Dishlex 160 Diswasher
I have Vulcan Dishlex 160 Dishwasher which was kept in good condition after using for few years, then it was NOT used for few years. When it is installed again in a newly constructed house having 3 phase power supply, the dishwasher functions well, does the job, but only just at the end of the drying cycle before completion of the washing job it makes some click noise and the power trip occurs. When intended to use again the same event recurs. Any clue please? I can't recall the name of the manufacturer. Also would it be possible to get an user manual print out from the web please?
Reply to:
Ranjanroy_MYDNAN@yahoo.com.au
Many thanks,
Ranjan
  • 750 Answers
Hello Ranjan_MYD Welcome
You said, You have Vulcan Dishlex 160 Dishwasher which was kept in good conditionafter using for few years, then it was NOT used for few years. When itis installed again in a newly constructed house having 3 phase powersupply, the dishwasher functions well, does the job, but only just atthe end of the drying cycle before completion of the washing job itmakes some click noise and the power trip occurs. When intended to useagain the same event recurs. Any clue please? I can't recall the nameof the manufacturer. Also would it be possible to get an user manualprint out from the web please?
Your machine is and Electrolux Dishwasher.
Here is a site you can get a manual from:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man&cmpid=RegEmail
Let me know how you do!
Huuum
Please remember to leave a rating!
Posted on Oct 22, 2008
The door is stuck closed on my Vulcan Dishlex 500 ECO Dishwasher. i have tried to lever it open with a spatula applying downward pressure on the internal latch w and simultaneously lifting the door...
Hi just read your posting.What you need to do is to get a pointy small knife and put it between the door and frame and move it till you stop at the internal latch.Now lever the latch up and pull the door open.The part you need to change is the t shaped plastic rod.Please turn off the power before you undo the screws to change the plastic rod.Please reply for further help or information.Looking forward to your reply.
Jun 19, 2011 | Dishwashers
How do i switch on the volcan dishlex 100s dishwasher
Hi just read your posting.Do you mean Vulcan Dishlex 100s?Have you got 1 big timer knob on the front right and 1 small knob to the left of the big timer knob?Or have you only 1 big timer knob?Please reply with additional information and I can help you solve this problem.
Jul 23, 2010 | Dishwashers
Miele Incognito G843SCVi Plus diswasher will not drain
if the timer is in good condition (no wires burned off)  then it must be the pump itself that need replacing  dishwashers need the drain hose to rise to the counter and then fall again to siphon and make the pump work easier  also it helps keep water in it to stop the plastic parts in it from overheating    if the hose doesn't rise and fall  it may have led to your failure
Nov 07, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Looking for manual for Vulcan Dishlex 500e dishwasher
Probably fatigued wiring from the chassis to the door where it bends every time you open and close the door. On my 500E, I took the sheet metal door skin off and found a couple of burned spots on the wires inside a clear plastic strain relief.
Apr 11, 2009 | Dishwashers
Water keeps running into dishwasher causing overflow
I had a diswasher with thils problem several years ago. The problem was wiith the plastic float at the bottom. It had hardend greese buildup that kept the float from moving freely. Removing the float and cleanning fixed the problem.
Jan 29, 2009 | KitchenAid Dishwashers
Dishlex Global 450 flashes ''oF'' - Continues to drain
I also had the oF error message just today, tilted the dishwasher back 45degrees and message dissappeared and all sweet as now. Put old towel under legs to catch overflow Thanks to david
Dec 29, 2008 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Bought a house with a Dishlex Supreme Deluxe Dishwasher already installed. It's an older model 8574 and we have no manual. Is it possible to get one somewhere?
Not sure if a manual would still be available but I can tell you that the Dishlex washer was made by Vulcan / Electrolux and was originally sold in Australia. You may want to check eBay Australia or some other online resources from down under! G’day mate!
Apr 01, 2008 | Dishwashers
Vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
Dec 07, 2007 | Dishwashers
Dishwashers Logo
379 people viewed this question
Top Dishwashers Experts
