Question about Aprilaire 550 Humidifier
Loud noise all of a sudden our humidifer is making a very loud vibration noise. At first we thought it was the furnace so we had tune-ups on the furnace and the also serviced the humidifer. It didn't make the noise while the techinican was here but is now getting more consistent in making the noise.
  • 2 more comments
  • joe7777 Nov 13, 2008
    I just changed the filter and now when the unit turns on and off it makes
    very loud noises from the water feed. Is there anything I could check to see
    if this could be resolved..Joe in Buffalo NY
  • buy789 Jan 14, 2009
    My 10 year old model 760 has started to make a vibration sound that travels through out my house. I figure I can repalce the whole unit, but would like to try and replace just the cause of the sound. I cleaned the fan blades and that seemed to work for about three weeks, but now the sound is back. Any ideas?
  • Anonymous Jan 16, 2009
    loud vibation sound echoes thru the whole house
  • buy789 May 11, 2010
    OK, I am going to try that and let this group know how I make out. Thanks!
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Posted on Jan 26, 2009
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
Hello kitty humidefier has started making a loud noise and sometimes it goes off but more often noise stays on longer. Almost sounds like a loud fan. What do I do?
This sounds like the electric motor bushings are worn which will cause vibration throughout the unit. If it is relatively new I recommend checking the warranty information and returning it to the retailer for a replacement. If you have gotten your money out of it but cannot tolerate the noise, then a replacement is in order as well. The cost of replacing the motor and installing it will most likely exceed the cost of a new humidifer.
Dec 08, 2010 | Crane Hello Kitty Humidifier
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Noisy Amana furnace
Remove the flue pipe from the top of the induced draft motor. Check to see if there any obstructions in it. If so remove them. If not replace the motor assembly.
Jan 02, 2009 | Honeywell Power Humidifier: Furnace...
Turning on the humidifier shuts off the furnace
It is possible you may have wired it wrong. Make sure your humidifer is not robbing power from your thermostat. This would explain when your humidifer makes a demand to come on it robs power from your t-stat making it lose its call for heat. Wire your humidistat to the "w" terminal and the common terminal so it only runs on a call for heat. With the bypass type of humidifier you purchased it wont do you any good to run when the heat isn't running anyway. If you want an independent operation humidifier you need a steam type.
Dec 02, 2008 | Aprilaire 600 Humidifier
FURNACE RUNNING LOUD
sounds like either the motor is off balance
or is going bad again
either way id be on the phone to the guy who did the rapair
more than likely the set screw on the sqiral cage came loose and now its vibrating
Nov 11, 2008 | Aprilaire 700 Humidifier
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
Aprilaire 550 Humidifier Logo
1,598 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
