Question about Apple iPod touch
IPOD Nano 4GB
My IPOD is frozen. When I charge it, it shows that it is charging. When it is complete I click the safely remove icon. My IPOD shows that it is safe to unplug. When I unplug it, the screen never changes. I have tried to hold down the center button but nothing.
Please Help, Thanks
  • Joe Camp Oct 29, 2008
    Thanks Very much it Works.
  • 728 Answers
First, toggle the hold switch. Then press and hold the center button and the menu button until the apple logo appears on the screen.
Posted on Oct 22, 2008
  • Jazz Boyce
    Jazz Boyce Oct 29, 2008
    Your welcome. No offense, but can you rate my solution please????
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
Hello im having a problem with my ipod nano, it was dying so i plugged it in to charge it and it wouldnt charge and then it died completely so i tried to plug it into my computer and see if it would charge...
First, safely remove your ipod from the system.
Then restart your computer while pressing F8.
You should see a list of options to choose from.
Choose last known good configurations.
Let the computer boot up completely and plug your Ipod into the back of the system.
It should detect your Ipod.
I hope this helps!!!
Jan 15, 2011 | Apple iPod nano
My ipod nano 4gb blue doesn't hold a charge. It's
If you left it sitting in the box "for a few years"...then that's why.
The battery has to be used to stimulate the "memory" of the battery. If it was charged once and never used again, then of course it is going to have a battery issue.
Nov 23, 2009 | Apple iPod nano
Don't know how to reject the ipod nano when charging at computer
  1. Once the iPod is attached to the iPod and USB port in the computer, an icon will appear at the bottom of the computer desktop. The icon is from removing the USB Mass Storage Device
  2. Now, click on the enject icon and it will show which drive the USB cord is attached to. Once the icon is clicked on, the iPod will show an arrow going down and reading "OK to disconnect". Once able to disconnect, the USB cord can be removed from iPod.
  3. Another way to eject the iPod from USB cord is through iTunes. Once anything you want sync'd to your iPod is complete, a message will appear on the iPod reading, "OK to disconnect". Just like it did on the ejecting icon on your desktop.
Sep 24, 2009 | Apple iPod nano
I jus gotta new ipod nano 2gb, i plugged it into the comp and it shows apple sign then "do not disconnect". a auto play window opened and it appears in "my computer". i click on it and it shows three...
First, you should use itunes for you iPod. I know that there are other programs that can let you load music on it, but you should use iTune, Really.
1. You should first download iTunes. It is free.
2. Next. Load your music into iTunes. Do all of this BEFORE you plug your iPod into the computer.
3. Connect your iPod to the computer. Use a fast USB port. These are usually located on the back of the computer.
4. Your iPod should appear in the iTune pane on the left side. You should be able to see a set of 'tabs' that you can click. The first one is about your iPod.
5. At this point, you can click on the music tab to tell the computer to load what to load into the iPod. Click 'sync' to load your music.
6. When the syncing is complete, you will see that notice above in iTunes. Click the arrow next to the iPod picture in the iTunes pane to discharge the iPod. The iPod picture will disappear. Make sure that you also safely release the iPod in the task bar at the bottom of the computer. You will need to click on a green icon that looks like a plug and select 'safely remove storage device'. Wait until the computer tells you it is safe to disconnect it. Then disconnect.
Hope that helps.
Dec 19, 2008 | Apple iPod nano
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
Oct 17, 2008 | Apple iPod nano
Frozen iPod Nano 4gb
hey i had that problem and what i did is let the ipod go completly dead and then charge it up again and it will unfreeze....
Aug 24, 2008 | Apple iPod nano
Charging ipod 4gb
Yes, the iPod will show that it is charging on its screen. Disconnecting without ejecting can cause data loss of whatever is stored on the iPod
Ejecting is when you remove the iPod from the desktop by dragging its icon to the trash or clicking on the down arrow next to the iPods name from within iTunes.
If you use the library computer, usually a Windows based OS, you'll need to click on the iPod icon from the task tray on the lower right of the screen. You can right click to select the remove option
Dec 21, 2007 | Apple iPod nano
Ipod nano, hitting eject results in system restart
First, make sure you have installed the software from the iPod CD. in any case, try to reinstall it. Second, Try connecting to a different USB 2.0 port on your computer. Last, Your iPod nano might need to be reset (see page 43 on the user guide). By the way: If you?re using a Mac, you can also eject iPod nano by dragging the iPod nano icon on the desktop to the Trash. If you?re using a Windows PC, you can eject iPod nano by clicking the Safely Remove Hardware icon in the Windows system tray and selecting your iPod nano.
Nov 28, 2005 | Apple iPod nano
Apple iPod touch Logo
35 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
