Question about RCA 20F420T 20" TV
TV TURNS ON BY IT SELF AND CHANGES CHANNELS AND FPA LOCK IS ON
I have bought a RCA 20" Television recently and I have just got all these problems all at once. I was a work and my TV turned itself on and started changing channels by itself, I had to unplug it and hoped it would fix itself. On top of that the FPA Lock is on now when I could control it and accidently turned on the FPA and now I can not get the TV to turn back on how do I fix problem?? CAN YOU PLEASE HELP ME!!
  • 41 Answers
The problem is there is engaged button there..only technician can do the job by replacing the button that is always engage.
Posted on Oct 22, 2008
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
My rca tv turns off and on by itself
Is there a prankster nearby thast has a remote tuned to your set? As a young lad I used to play this trick on my neighbors daughter.
You should also investigate whether it is timed.. that is has a regular interval or time that it does happen. It could be another appliancwe doing this A/C ,Security system or some other eklectronic device. The dog has the remote under the cushion?
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | RCA P52960 52" Rear Projection Television
Tv turns off and on by itself. It alsoo changes
This sounds like the front panel assembly(FPA) switches are acting up. What happens is the FPA switches start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to do erratic things.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disasembly. Note:The remote will still work with the FPA removed so the set can be tested.
Let me know if you need more help or info.
Post back with make/model info. (the problem is common especially with RCA)
Nov 28, 2009 | Televison & Video
FPA LOCK IS ON AND I HAVE NO REMOTE FOR THE TELEVISION,,, HOW CAN I FIX THIS?
You will need an RCA Remote or Universal (RCA) may work. Once the Front Panel Assy. is locked the TV will only Power on with a remote. Call an Authorized RCA warranty service center, and offer to leave a deposit for the use of the remote. Power the TV on with the remote. Press Menu on remote. Press CH- (down) button on remote to highlight "Preferences". Press OK button to open menu. Press CH-(down) button to highlight "FPA Lock". Press Vol.+ button to turn off FPA Lock.Press Menu button to return to Main Menu. Press Menu button again to clear On Screen Display.
Dec 23, 2008 | RCA 20F420T 20" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
FPA lock on a magnavox
The only way to fix it is wit remote , get your self a universal remote and do manual search until set switched on , then go to menu and turn lock off before it happened again.
Jun 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
RCA 20F420T FPA lock
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jan 21, 2008 | RCA 20F420T 20" TV
Rca 20F420T
if you can bring up the menu try using the volume up / down and channel up/down on the remote to change your selection. that might work
Sep 01, 2007 | RCA 20F420T 20" TV
FDA Lock
I have never heard of FDA lock. If you mean FPA lock, this is the Front Panel Access lock (also called Child Lock) built into the TV. To unlock FPA, turn the set on with the original remote, enter the menu, navigate to the page with FPA and set it to off.
Aug 21, 2007 | RCA 20F420T 20" TV
RCA 20F420T 20" TV Logo
235 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
