Question about Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty washing machine
You responded to my question but I do not understand what information you need. There is a gasket or small belt that is just under the tub, around a pulley or gear...in a diagram it is in the location of the clutch liner or brake liner ??? it is about 1/4 inch wide maybe 5 inches in diameter (8-10 inches around???) Hope you can help.
Thanks
Kris
    Sergeant:
    Champion:
  • 291 Answers
Tell me what your problem is and what your trying to do and i will see if i can help you / larry
Posted on Nov 25, 2008
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
I have an old kenmore washer, on which I cannot find the model number. It needs a new drive belt. The only information that I have is that it is marked as a Kenmore Heavy Duty 80, and inside the door is...
Go to a local Sears or Whirlpool store and tell them you have an old "belt drive" Kenmore washer that needs a new belt. All of these were built by Whirlpool Corporation and I believe used a common belt.
Good luck.
Mar 25, 2011 | Washing Machines
I have a Kenmore Heavy Duty Plus washing machine, which has had the belt replaced, but the washer will not agitate or spin
who replaced the belt? if it was a service tech, he could have putten the wrong belt on. it happens.
Dec 31, 2009 | Washing Machines
I need to replace belt on kenmore heavy duty washer, do I have to remove drive unit?
MOST NEWER KENMORE WASHERS ARE DIRECT DRIVE AND HAVE NO BELT,THEY HAVE A COUPLER BEWEEN THE MOTOR AND TRANS,LET ME KNOW IF THIS IS THE CASE WITH YOURS-MIKE
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Need the belt routing for my washing machine
unless you washer was bought prior to 1988 there is no belt ..washer is direct drive with coupling between motor and gearcase
Jul 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
