Question about Plumbing
He center piece of kitchen faucet (where hot/cold water comes out, has popped up off it's base
I have a Price Pfister faucet with a center spigot where the hot adn cold come out together. Tongith I ran the water and the pressure just blew it off. I can see the threads on the part that came off but can't see how to screw it back on, since the spigot will not turn a full 360 (the backsplash is in the way) Do I REALLY need a plumber for this??
  • 374 Answers
Iam assuming you are refeerring to the aerator which is a small round object with small screens inside of it through which the water runs. It mixes air into the water to give it a more uniform and controlled flow pattern as well as filtering out some debris. If this is the case than you could do the job yourself as long as thee threads are still good internally and externally. The piece screws into the bottom of the spout and the the threads it screws into are internal and therefore are not visible while the faucet is attached unless one is a contortionist. The threads usually are fine and sill usually screw in with little effort. If you encounter a bit of resistance you may be cross threading it. Just back it off and try again. It is a very doable task. Thanks for using Fix Ya and I hope I have been of assistance. If you need further help please let me know.
Posted on Oct 22, 2008
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
Just purchased the Price Pfister 42-YP. The hot water has limited water - just a trickle. What can i do to adjust?
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Aug 31, 2010 | Price Pfister 42-YP0E Ashfield Single...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Aug 31, 2009 | Plumbing
Installed a new price pfister two knob kitchen faucet and the cold faucet turns off backwards. How do I make it shut off in the right direction ? Thanks !
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Jun 28, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
526 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
