Question about Canon PowerShot A85 Digital Camera
Dark pictures with flash
When i take a picture the flash goes off but my actual picture is dark and grainy. i have new, powerful batteries. The camera is on auto. This is the setting I've used for 3000 pictures and I've never had a problem before now.
I had this problem before, sent it off to have it repaired 1 year ago, and now have it again. Just to make sure it's the same problem, here's a description: The flash seems to be out of sync with the shutter. Using the flash in medium or low light (in auto mode) makes the picture darker than not using a flash at all. It ruins the picture. In a completely dark room, even though the flash fires, the pictures comes out pitch black. The problem is the flash unit -- it needs to be replaced. If your camera is under warranty, Canon will replace it for free. (You pay only to ship it to them.) (You might try what they told me to try before I shipped it off, and that was to reset the camera by pushing and holding the menu button until it resets. Didn't do anything for mine, but who knows.) If it's not under warranty, Canon will offer to replace it with a refurbished newer model for a discounted price. That's my situation now, because the problem has come back. I did come across a posting that described how to replace the flash unit yourself -- it involves taking the camera apart, but looks doable. (Sorry, I don't have the link handy and I'm not sure if I can find it back.) The problem is, I don't know where to get the part. Canon has been no help on this. Anyone know where I can get a Canon flash unit for the A85? Hope this helps, and good luck.
Posted on Nov 14, 2006
SOURCE:
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
All of the pictures are grainy and very dark- not usable camera at all- less than 2 years old I have re formatted the SD card, changed the batteries, and reset the camera to default settings
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Feb 24, 2011 | Canon PowerShot SX110 IS Digital Camera
My canon powershot s3 IS is taking really dark pictures. The only decent pictures I can take with it are outside in sunlight. Pics indoors come out dark and grainy. I flip up the flash, but most of the...
This is not an answer. The S3 normally does not produce dark pictures, and I have seen this issue before. It has to do with a setting somewhere on that camera that needs to be adjusted. I wish I knew what that setting was/is as my wife's camera has recently started doing this ...
Jan 04, 2011 | Canon PowerShot S3 IS Digital Camera
Bad indoor pictures. When I take indoor pictures and it says to use the flash I do but then my pictures turn out dark/grey. Then I try it without the flash and they are brighter but then blury. I even...
The flash has a range of up to around 10 feet at the wide end of the zoom, down to 6.5 feet at the tele end. Maybe you are using it on to big a distance or at to low ISO? Try setting the ISO to 800 and see if it helps. images get a bit more grainy at 800 ISO but are also less prone to camera shake, if you use it without the flash. The camera goes as high as 1600 ISO, but images get very grainy at that setting.
Jul 01, 2010 | Canon PowerShot SX100 IS Digital Camera
Screen goes dark between pictures
Probably a power saving - OR- a timer setting.You should be able to change the setting easily.
Mar 18, 2009 | Canon Powershot SX110 IS Digital Camera...
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Sony dsc730 when i take a picture camera won't flash and picture
the camera doesn't stay on and it won't flash when picture is taken and when it does the picture is too dark
Dec 21, 2008 | Cameras
Flash not working
posted by greenbean on Jul 28, 2006 Report abuse
when i take a picture the flash goes off but my actual picture is dark and grainy. i have new, powerful batteries. The camera is on auto. This is the setting I've used for 3000 pictures and I've never had a problem before now. if(typeof LIB_LOADED == 'undefined'){document.write(''); } Solve This! postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> I have the same problem -->I have the same problem.
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Nov 14, 2006 3%20stars.png
noavatar_s.gif Hawic
Rank:nonexpert_s.gif Apprentice
Rating: 90%, 2 votes
Was this solution helpful? Show your Appreciation by rating it:
Sep 01, 2008 | Canon PowerShot A85 Digital Camera
Dark pictures
Check whether the ISO rating set in the camera is correct. Also, if the images are grainy and dark, it may be an issue with the exposure.
Dec 31, 2007 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Canon PowerShot A85 Digital Camera Logo
138 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
