Question about Sharp CD-BA2600 CD Shelf System
When switch on my sharp radio ;generate some noise like helicopter,
I changed many capacitors too but the problem is same.
  • 446 Answers
Pardon me for asking why do you have to changed the capacitors, cap usually have rating and values, unless you have good reason to changed these, ensure you are replacing the same ratings.
noise from radio usually occurs if there is interference of some sort, or insufficient or fluctuating voltages
if the sound seems high pitch, then it is from capacitors you have replaced
Posted on Oct 22, 2008
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Dewalt radio problems
The resistor of the potenciometer at volume is malfunction.
Change the potenciometer.
Sep 03, 2014 | Dewalt Dc012 Cordless / Corded Worksite...
How to fix a syma helicopter if it is not responding
My helicopter used to do that too I called the company and told them my problem they said to change the batteries in the helicopter in a week they delivered the batteries and my helicopter was working agaim
Apr 21, 2014 | SYMA Toys industrial New Syma S107 Radio...
Do the helicopter itself have a on/off switch..tech-one gallant
After fights between teh kids (he's crashing my helicopter) I think I figured it out. The instructions says to select the frequency on the helicopter, but there is no switch. When you first bring up the helicopter and controller, sometimes the green light on the controller blinks a few times. That is it synching up with the helicopter. After you charge the helicopters, turn then both off, Then turn on one helicopter and one controller. The key is when the green light above the one off switch is blinking. I did it with trial and error, so I am not sure exactly how to get it in the mode where it is in pairing mode. RIght now I am reluctant to mess around with it because they are set correctly and the kids are playing with them. I will post later if I figure out the exact sequence for getting them in pairing mode
Dec 26, 2013 | SYMA Toys industrial New Syma S107 Radio...
Radio static from cooper wiring devices occupancy sensor
Use only incandescent light bulbs on those and test again.
Nov 21, 2013 | Cooper Wiring Devices Occupancy Switch...
Inferred controller loses contact with the S107G
Moving to solution section so more people will see it:
Infrared is different band of electromagnetic spectrum from radio and is subject to the same problems as radio waves, namely, noise, transmitter problems, and receiver problems. the receiving antenna will not be a wire, it will be a infrared photocell. The sending "antenna" will be an LED.
A few things to try..
- make sure that nothing is covered on your handset and the helicopter that did not come that way
- Switch channels
- try a different location to see if anything in the environment is interfering, it could be something generating a lot of heat (including bright lights or sunlight) or another infrared device, like a remote control or some wireless devices like headphones and 3D video game systems with active shutter glasses.
- turn everything else off where you are trying to fly - might have to unplug electronics and remove batteries from remotes to make sure they are not emitting
- try linking a different helicopter or different controller that you know works to see if it is on one or the other of yours
I tried putting my hand over the emitter and the helicopter, and could not block the signal. I flew mine to the balcony out of site, and it still responded fine, so the signals bounce around enough quite a bit.
Jan 05, 2012 | SYMA Toys industrial New Syma S107 Mini...
Bought a S108 helicopter. Charged the helicopter and lights are flashing but it looks like the remote control does not work. I have never seen the LED light on. Helicopter has not move an inch yet. I have...
There should be a sticker near the helicopters "on off" switch that has an "A" "B" or "C" on it. Make sure the switch on the controller is set to correspond with that letter. If that isnt it, keep it for parts and buy another. These are VERY delicate toys and most break quite easily.
Dec 27, 2010 | SYMA Toys industrial New Syma S107 Radio...
1989 f150 has wierd fax noises on am & fm worse at low end of band. worse in am than pm
Check if noise is only present with motor running -
if so, may be radio interference generated by the alternator - check alternator suppressor capacitor is ok.
If noise is present when ignition on but motor not running, the interference is possibly being generated by some other electronic device on the vehicle - disconnect device/s or remove fuses and note effect.
Mobile electronic equipment such as phones/ satnav etc can also generate interference.
Sep 30, 2009 | 1989 Ford Mustang
Sharp CD-BA2600 CD Shelf System Logo
192 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
