Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Picture has a shadow (double effect)
The picure has a doubling effect kinda like you should be wearing 3-d glasses to get a clear picture. I just bought the tv from a friend and have no manual. He says it was fine before and probably messed something up from laying it down while transporting it
  • 1 more comment
  • ubu3n9 Oct 22, 2008
    I was able to research on how to enter 12C service menu nad found one posted by premtech. Probem solved!!! Thank you
  • DLPH Dec 04, 2008
    have tried to log into service screen, coulple of times but that particular screen is not appearing on the screen, is there any other way to acces
    set up?
    Thanks.
    G.
  • mmcarpentry Jan 13, 2009
    I also have this problem. But I can't get to the sub-main menu. You
    said to enter the 12 c service menu . Can you help me? I have a shadow
    or ghost effect to my picture. I have had my T.V. fixed twice before .
    The second time the technician showed me how to fix it by myself , but
    I forgot how to . I need your expertice.
    Problem Solver:
  • 3 Answers
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Jan 19, 2009
  • 61 Answers
From your description I think your problem is "Ghost" or you can say out of convergence.
If you know how to enter I2C Service Menu it could be done with in couple of minitues.
Means you have to change some values of light engine to avoid double image.
Dont Forget to Rate!
Good Luck
Dals123
Posted on Oct 22, 2008
Seeing double- almost like a shadow or 3-d when you aren't wearing the glasses
Thats a convergence issue. You can get the repair kit for that model hitachi from www.tvrepairworld.com under the Hitachi Repair Kits page.
Mar 22, 2013 | Hitachi 51F500 51" Rear Projection...
I have model number 60pp9202 and the screen is mostly red and green and when words come up there is like a double image
Tv have any colors lines R,G,B mis alignments,have a colors shadows picures or a 3D pictures look alike?Yes?The tv have a problems known as a convergence pictures problems,it is dead and the problems.The tv convergence board must have to be repair like replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv pictures convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 30, 2011 | Philips 55PP9502 55" Rear Projection...
Cannot correct convergence the green line is double
The tv convergence board is dead.Any colors lines R,G,B mis alignment,have colors shadows or 3D picure look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Nov 06, 2010 | Toshiba 42H81 42" Rear Projection...
53UWX10BQ - DOUBLE IMAGING OR SHADOWING
Good Day, sh28;
Sounds like bad convergence IC’s, chips. Hit recommends using STK392-150’s and replacing the bias resistors.
Good Luck, Big Irish.
Jun 23, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Our Samsung Tantus Rear Projection TV, the colour is a problem, on the right hand side there is a red shadow next to the picture so it almost seems as if the picture is doubled. I have a double picture...
Sounds like a convergence issue with your RGB colour channels - probably need to get it serviced and have the convergence tuned.
Unlikely you can do this yourself.
Papa
Jun 20, 2008 | Televison & Video
Double picture
Youre convergence Ics need to be replaced. Use STK392-120 Ics you will need to replace both of them. You can get replacements at the following link and they provide free instalation instructions with pics.
http://servicemanuals.vstore.ca/
Jun 15, 2008 | Philips Magnavox 9P6034C 60" Rear...
Shadow effect
I think it's called "tubes" for the TV, the projection tubes are messed up, and you probably killed your bulbes. Very expensive to fix, just part out what can be used and get a new TV, or get a 60" tv with a smashed screen, and reuse your screen. People sell those on craigslist.org all the time with broken screens because they do not know how to replace them for only 100-200$
Apr 05, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Double picture
Can you give more details? What do you mean by Double picture? Do you have 2 pictures side by side or One on top of another? Or is it like a shadow behind the main Image? If it is a shadow (Ghosting), check your Antenna - connection, direction, etc.
Sep 05, 2007 | Sony FD Trinitron WEGA KD-27FS170 TV
Copy is not clear and the txt is double
Sounds like the scanner is not moving freely. Try lubricating the scanner rails. And the obvious, clean the glass with windex.
Nov 20, 2006 | HP 610 Color Copier
Regarding the display when I play DVD/CD
I dont umderstand what you mean by shadow Can you take a picture and attach it here?? I need to see what your talking about as I dont understand.? Im kinda thick sometimesLOL Thanks.
Apr 14, 2006 | JVC HR-XVS20 DVD Player/VCR
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
257 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
