Question about Roper RAS6233KQ Top Load Washer
Roper Model RAS6233KQ Spin Cycle doesn't get the water out
I smell a loose belt and the spin cycle doesn't get the water out of the clothes.
Max 801.690.6398
maxferg@gmail.com
    Problem Solver:
  • 10 Answers
Its sounds like the pump has frozen, If your smelling the belt burning its either that, the tranny binding, Or the tensioner has a defect (very unlikely). If its washing, agitating and spinning okay its the pump. Get ya a new belt while your at it!
Posted on Oct 22, 2008
Roper RAS8333RQ0. If I put more than 4 or 5 pieces of clothing in it won't agitate or spin. I checked the lid switch and it seems to be OK, as it agitates just fine if the load is small enough.
A couple of ideas.
First, type in your model number to the web-site named: "SearsPartsDirect".
The schematics will show whether you have a drive belt on that model.
If there is, that belt may be slipping, or worn out.
Before you order a belt, consider this.
If the machine is not properly spinning out the water on the spin cycle, ( for example, if the belt were loose), then too much water may overload the machine causing your problem.
God bless your efforts.
Nov 27, 2017 | Roper Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Spin cycle switch broke off on the under panel where clothes go in..... will this effect the machine?
Yes it will. The machine should not go into a spin cycle if the switch is not closed. It can also hang down and fall into the water in the tub. They are inexpensive and easy to replace. Here is a link that should help
replacing a lid switch
Oct 20, 2010 | Roper RAS6233KQ Top Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
The spin cycle will not spin properly, the clothes at the bottom are still dripping wet and I do not overfill the washer, and its on all cycles
Your drain pump is not draining properly. Remove from washer and inspect the pump section. Check for blockages or obstruction in the pipes.
Sep 21, 2009 | Roper RAS6233KQ Top Load Washer
Roper Wash Machine Model # RAS8333RQ4
check the switch under the door , it could be damaged , check with a multimeter at OHMS setting , if there any reading then switch is OK , if not try to clean it up with tuner cleaner , you can purchased at RADIO SHACK.
Dec 17, 2008 | Roper RAS6233KQ Top Load Washer
RAS6233KQ2 TOP LOAD WASHER WILL NO SPIN CLOTHES
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Nov 03, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
93 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
