My washer spins but makes a terrible screeching sound. Could it be the bearing?My washer spins but makes a terrible screeching sound. Could it be the bearing?
We are having the exact same issue. I had hoped it was just the belt slinging around making all the noise but it looks good. Help!We are having the exact same issue. I had hoped it was just the belt slinging around making all the noise but it looks good. Help!
You can't post conmments that contain an email address.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
sounds to me like you have a bad transmission
what happens when you take the agetator off
does it still make the noise or does it go away?
if it goes away when you take the agetator off then you have a bad agetator
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition. Thanks
Most noises from a washing machine occur during
the spin cycle. If you hear loud thumping during the spin, the load of
clothes may have become unbalanced. Stop the washer and redistribute the
clothes, then re-start it. Repeat these steps if necessary.
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
