Question about Proscan PS36125 36" TV
Tv turns off
I have a 36inch after it is warm it turns itself off and sometimes back on, but recently it goes off and does not turn itself back on unless I turn it on. I have tries your suggestions by plugging it directly into an outlet by itself, turning all lights off in the room, and even sent it out to have it repaired and they could not find the problem. please if you have any suggestions I would appreciate them. thank you
    President:
  • 3,130 Answers
Ok this problem is a common one but if you never ran into it you wouldnt know. The small coil L401 from the secondary of the horizontal driver transformer to the base of the horizontal output transistor need to bee taken completely out. The enamel on the coil on both sides need to be scrapped off and NOT JUST RESOLDERED!! Then reinsert the coil into the printed circuiyt board, and then resolder. This is not a job for the amature or the di it yourselfer as way to much High Voltage to experiment with. Good Luck
Posted on Jul 28, 2006
My Samsung LC55C630's backlight sometimes turns off. Recently it has been consistently turning off when I switch HDMI sources. Do I need to replace the backlight inverter?
have you been in the back could just be lose connector from power supply to inverter board worth a go or you may see some think else standing out leave tv off at least 10 mins or discharge it if you know about tv witch it sounds like you do good luck
Mar 04, 2018 | Samsung Televison & Video
Sanyo LCD 36inch - there is coloured lines going across screen until te tv warms up and then stops . This lasts for at least an hour . Any suggestions?
This is usually related to a defect in the screen itself, or the video processing board. Repairs may not be cheap, would tolerate as long as you can, and maybe just turn on a little before you plan to use it.
Oct 19, 2012 | Televison & Video
TV turns off by itself or volume goes out usually within the first 15 minutes. The volume will go off and then I'll try to change stations and tv is black, I have to turn off, wait till the VIZIO light...
your Audio output chip has gone south and shorts out after warm up The unit will shut off to protect itself you need a tech to replace it try Pinicle Service solutions in Haverhill ma
Nov 02, 2009 | Vizio GV46L 46 in. LCD Television
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
Screens nturns black but have audio
Ur video board is dead.Or the video socket connect to the CRT(tv tube) is cold solder.
Sep 06, 2009 | Sony KV-27V40 27" TV
Samsung HL-P6163W DLP sometimes turns on with NO PICTURE
sounds like the dmv pcb bpard cost 597.70 and about a 250 core charge from andrews electronics.
or you can look ay the price at partsstore dot com.
regards,
daniel.
Jan 09, 2009 | Samsung HLP6163W 61" Rear Projection...
My Grundig tv turns itself off
Its Probably overheated.
happened to me before then i took to fixers and they changed some part and now its fine or if u have a warrenty call the manafactuarer
Dec 13, 2008 | Proton MM2701VT 27" TV
you have a bad CRT causing the set to shut down. after the CRT has cooled down the computer finds all value to be ok then comes back on....
Jan 07, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
80 people viewed this question
Top Proscan Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
