Question about Dayton Electric Heater
Dayton 2yu62 doesn't work at all
I have two Dayton 2yu62 heaters and neither one works. Checked and confirmed that there is power at all connections when thermostat is on. Checked overheat switch. No problems there. Thermostats are working but nothing comes on. No reset switch. HELP!!!
  • 1 more comment
  • Tom Cline
    Tom Cline Oct 22, 2008
    Will check the heating elements tomorrow morning. I don't this heating elements are the problems as the fans do not work either.
  • Tom Cline
    Tom Cline Oct 24, 2008
    Thanks for your help. Found the problems with the wiring between the breaker box and the heating units. One of the line wires had enough connection to show voltage but not enough connection to allow enough current to run the heaters (impedence too high). Don't you just love it when the building wiring diagram doesn't match with what is actually wired. Someone added another heater in the upstairs office and tapped into the wiring to the commercial heating units. Is fixed now. Again, thanks for you help.
  • Anonymous Nov 20, 2008
    notheing works with this heater the light is not on it is plug in nothing works?
  • 108 Answers
Need to check heating elements and replace if necessary. If your checks are complete that is the answer I think.I suggest reviewing your findings. The heating elements rarely go bad.
Posted on Oct 22, 2008
  • Ray Oct 24, 2008
    Using jumpers, send power directly to the heaters and or fans. If they work then you missed reporting a control device. Usually heaters have a thermal fuse in addition to an "overheat switch". Be sure youir jumpers bypass this protector. The fans come on with the thermostat.
    Ray
  • Ray Oct 25, 2008
    I am glad your problem is solved
    Ray
Fan doesn't turn on on auto
Sounds like the automatic fan control is not working afc you can take this out it can get cloged with dust on the back of it clean it and see if this works also check your air filter is clean .
Mar 21, 2012 | Dayton Gas Furnace Heater
Dayton (3E133) hooked up wont work at all
The 3E133 (or similar) Infra-Red Heater with correct voltage to the circuit board should produce a spark at the spark ignitor rod within a few seconds of having power applied. If it doesn't, one of the following could be the problem: (1. circuit board (ignition controller) is bad. (2. The gap between the spark ignitor rod and the middle rod (ground) is incorrect. It should be between 1/8" & 3/16". (3. There is not a good ground. This could be due to rust or a loose connection at any point between the equipment ground and the spark ignitor rod, including the ignitor mounting screws. (4. The spark ignitor rod or its orange wire is grounded, such as touching metal and thus "short circuiting" rather than allowing the spark ignitor rod to be 1/8" from "ground".
That's all I can think of that would cause NOTHING to happen.
Dec 12, 2011 | Dayton (3E133) InfraRed Heater
When I plug the Dayton 3VE50 heater in, it comes on for about 5 seconds and shuts down?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 18, 2011 | Dayton (3VE50) Oil Filled Liquid Fuel...
What type of thermostat do i need to hook up to a 2yu62 heater
don't know about the heater to much but you can get range of t/stats and a majority can be wired into different types of heater firstly i'd get a sparky to come and see if he can wire a universal t/stat into your heater.
Nov 17, 2010 | Dayton Electric Heater
I have a Dayton Electric Wall Heater which I bought last year. I tried to turn it on but it didn't work. The model is 3UG55D. I checked the power which was fine. Then I cleaned it from the inside and it...
Ohm out the element...make sure that is good...
also ohm out the thermostat to check that out...
basically just follow the power to see why it is not
making the element heat....
You can get parts from www.grainger.com
heatman101
Sep 14, 2010 | Dayton Electric Heater
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
Flames burn then die down
it sounds like you may have a dirty pilot tube or a weak pressure regulator. I would try blowing out the pilot tube to make sure it is clear and if that does not work then replace the regulator.
Feb 14, 2009 | Dayton Gas Furnace Heater
Heater wont work
Dayton heaters. com?
14 years old? dayton still exist?
Stop trying to blow self up--go buy new one
Jan 21, 2008 | Dayton (3E379) Heater
My E 50 Dayton heater
it could be a power connection problem or possibly a safety shutoff
Dec 27, 2007 | Dayton E50 Heater
Dayton Electric Heater Logo
389 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
