Question about Kitchen Ranges
My GE range....
Thanks for all the effort.... no, you're not a fool..... here's the proof....
Dont look no more! I've changed the sensor (50$) and it's working perfectly!
  • 750 Answers
Please remember to leave a rating!
Posted on Oct 22, 2008
I need a full proof proxy for youtube
Trying asking for a "fool-proof" proxy.
There is no such thing as a "fool-proof" proxy. Your ability to use a proxy depends on where you are trying to reach it from. If you are on a corporate network, the security folks may be blocking access not only to YouTube, but to proxy servers as well. The best thing I can recommend to make it "fool-proof" is to stand up your own proxy server and use that. Odds are the filtering apps that are used will not have your server identified as a known proxy.
Dec 10, 2010 | Computers & Internet
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
When we try to turn the bake function on our Ge profile for the oven we get the f3 error code
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 04, 2010 | GE Kitchen Ranges
Oven keeps cutting off with a code flashing F3
Hi
Thanks
Rylee
Jul 03, 2010 | GE JBP25 Electric Kitchen Range
Oven will not work
With a gas range, I wouldn't fool with it. Get a service man out there now! Gas stoves are great untill they malfuntion and need a qualified service person to check it out. It's cheep insurance if there is a gas leek causing the problem. The alternitive-------!
May 21, 2009 | Kitchen Ranges
GE temperature sensor came loose
really no difference how it hangs, so long as it doesnt touch the oven walls, and is up high enough so you dont hit it withthe pans/food you put in
Dec 11, 2008 | GE Profile JTP18 Electric Single Oven
Stove shows error code of F2-E1. None of the oven controls will respond. The stovetop burners are fine.
Could be a sensor problem. I've just changed mine on my GE range. Cost is about 50$ for a new sensor (plus time if you cannot install it yourself).
Time to repair : about 20 minutes (2 screws inside the oven, 6 on the back panel. Remove the faulty sensor. Put the new one. Put the screws back... and voila!)...
Oct 21, 2008 | Kitchen Ranges
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Range Problem
f3 is a faulty oven sensor, 2 scxrews and a wire connection, located in the top left corner of inner cavity, pull it out and bring it to a local part warehouse, change yourself for 50-75 bucks
Mar 31, 2008 | Kitchen Ranges
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
