Question about Makita 3 x 24" Belt Sander
My sander wont start has the brushes worn out how to swap them
I've had this sander for years and it has been very reliable.Now though it just wont start.'m wonderng if the electrical bushes heve worn out and how to replace them.
    Novelist:
  • 99 Answers
The brushes are easy to check and replace. You will see a small disc to the right of the handle on teh motor body, and another on the front side. These are your brush caps. Simply unscrew them and you will see the brushes. They could just be stuck with sawdust so pull them out gently and check the length. Most makita brushes have a wear line that indicates when you need to change them, but generally if the holders are clear and teh brushes are tou ching the motor, the brass head should stick out a few mm before the caps go back on and this should be enough to give you time to get a new set in ready. The brushes will only fit in the holders one way.
Posted on Oct 25, 2008
Ka280 sander sparking in handle.smell of burning
Brushes in motor may be worn out. Should not be dangerous but might want to look into a replacement before it wears out completly.
Jan 12, 2015 | Sander Tools & Hardware - Others
Rockwell 361 belt sander wont run i have power to switch switch good bad brushes?
Brushes wear out often. Unscrew the brush caps and see if they are worn really low or if the springs are broken. If there is any burning on them, then replace them. Also those brushes sometimes stick in the brush holders because of the amount of dust. When you remove the brush caps, blow out all the dust you can.
The wires that go to the brush holders have springs that wrap around the inside of the brush holder (see picture). Check and see if those springs are broken or if those wires are not connected. Sometimes the fields go out in those but it's not too common. Almost never is it the armature (unless a bearing causes it but that's a mechanical failure, not an electrical issue).
Apr 13, 2012 | Tools & Hardware - Others
My Bosch 1276 DVS belt sander abruptly stopped working. Could it be the switch?
that is possible, but was the tool operating properly first?? unplug tool and check the cord for any breaks, then what I would do is clean the tool as good as possible with compressed air and if you can remove the brush caps do so and check the condition of the spring and clean the area. DO NOT sand the brushes but look across the face to see if both look worn evenly. If you have a volt ohms meter check from the plug to the brush holder with the switch on brushes removed to see if you have continuity and if not then I would have to think the switch
Feb 11, 2011 | Bosch 1276DVS 4" x 24" Dustless Variable...
Model no 333 wont start unless i turn it on its side?
It sounds to me that you have used the sander a lot and the vibration has broken a wire or it's about to break on the field windings. The brushes you need to look at to see if worn. But I kind of think wire problem. I had this happen on mine and opened it up to find this is what happened. The sander would be turned on and would not operate until I turn upside down and it would work. This is great if you are sanding upside down but this is just a sign that you are on borrowed time as this will eventually not turn on at all. I was able to fix mine with new wire crimp connection and solder with heat shrink material. If not you can order new field winding if this is what is wrong. Cleaning up the sander won't hurt either. You might want to see what a new sander will cost vs. part. Good Luck!
Aug 15, 2010 | Porter Cable 332K Quicksand Random Orbit...
I have two rupes sanders, one is approx 15 years old ,the other approx 5 years old,both are stopping while working or sometimes wont turn on,if I tap the sander with a hammer then they start to work or...
it can be ascertained, there is a problem in the switch or the motor carbon brush, carbon has been eroded by the rotor rotation. you have to check and replace the carbon or switch.
Aug 05, 2010 | Tools & Hardware - Others
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Stopped working might have overheated it does nothing now
have you checked the fuse first.
possibly worn brushes on the motor, remove the brushes and check the length of them , also look to see if they are pitted or burned.
Jul 18, 2009 | Dewalt 3" X 21" Belt Sander
I have a type 2,#92 heavy duty sander,length of right angle sander is 14".. approx 35 years old............need brushes. whee can I find these please...
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
Jun 12, 2009 | Black & Decker 4.3A 6" Heavy Duty Right...
Porter cable 352vs belt sander wont run.... was running fine grinding down subfloor untill the end of the day...next day it won't start at all? any ideas?
The very first thing I would check is the condition of the motor's brushes. I'd bet just about anything that they're just worn down passed the limit length. I have the same model PC belt sander... and have used it to do that very same task... I came upon your query because I'm shopping for new brushes. This is a very easy fix by the way.
Jun 09, 2009 | Tools & Hardware - Others
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
Hi
Definately sounds like bad switch or contact to the switch
Feb 26, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Makita 3 x 24" Belt Sander Logo
363 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
