Question about Olevia LT37HVS 37 in. LCD HDTV
On and Off
Hello! i have Olevia tv model# 226V LCD TV, it was work very well but yesterday it. can On and Off. what can I do??. I plug It , hand have a red ligh , but don't see a imagen and sound. thanks. mY e-mail Viento86@hotmail.com
  • Olevia Master
  • 5,568 Answers
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Nov 23, 2008
My olevia tv sparked immediately I put it on ,and refuse to turn on.
Sounds like LOT arcing. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here.
Jul 02, 2015 | Olevia 26" 226v widescreen hdtv lcd tv...
No sound
TV was working okay yesterday The screen is showing no signal when I turned it on this morning, I check the cable hookup
Nov 19, 2013 | Olevia LT42HVi 42 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
On my Olevia 42'' LCD TV, the tuner option in source stopped working. I now have HDMI, Composite, etc but no tuner. How do I correct the problem so that I can access tuner. Firmware ends in 060608B....
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Dec 24, 2009 | Olevia LT42HVi 42 in. LCD Television
Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Sep 13, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Need Code for Olevia LCD TV
there is no code for olevia.....(olevia, vizio and dynex are really new) All universals are not yet ready for theses new flat panels.............but you can use olevias remote (rc-ltu) it controls five units (cable box, olevia tv, pioneer laser disc and toshiba dvd plus a vcr if i had one)
Dec 20, 2008 | Directv RC23 Remote Control
Olevia LT42HVi - Need to toggle power switch on back of TV off/on all the time
You swapped the power strip. How about swapping the cord with another. Most LCD and Plasma TV used a cord similar to the cord use for the power supply of PC (IEC line plug). If still it doesn't work. Time to open the back to access the connector terminal which came loose (Due to heat) if not soldered directly to the power supply PCB. Just pinch the spade crimp, better still solder it. Make sure to lay the TV flat, face down on a smooth surface table if you're repairing it yourself.
Good Luck.
Dec 21, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
91 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
