Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Top Rack not cleaning
Did you ever get an answer
tdyck@comcast.net
    Genius:
  • 2,035 Answers
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Good luck
Posted on Oct 22, 2008
  • 749 Answers
The unit jets water up from the bottom to the top , make sure you do not block the path of the funnel to the center top with a bowl or plate while loading it.
    Brigadier General:
  • 6,966 Answers
Your concern "Top Rack not cleaning" often would indicate that the unit is not receiving sufficient water and the basin does not reach full level. Based on this, it may be required to check:
  • incoming water pressure;
  • water inlet valve;
  • incoming filter (if one is installed);
  • other areas to check are: heater (125 to 140 degress reached?, does the pump work? visually inspect the spray arm for any cracks, splits or possible leaks;
  • you may also want to verify that: the dishes are loaded properly and/or try a different detergent.
Additional insights may be sourced from here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Www fpl com updateemail
Comcast email support to update email:
  • Sign in to My Account.
  • Click the Users tab at the top of the page.
  • Select the user you want to add an email address for.
  • In the Personal Contact Information section of the user page, click the Edit button next to the Additional email.On the next page, click Add a personal email address. (Note: If there is already a personal address associated with the username, you can click Remove and start these instructions over.)
  • Enter and re-enter your email address. Click Add Email.
  • We'll send a verification link to validate your new email address. For your security, your email verification link will expire in 72 hours.
Note: Your comcast.net email address will remain your default preferred address until you update the setting in My Account. To know more you can contact Comcast Business Internet Support Number.
Sep 08, 2014 | Computers & Internet
Unable to access my e-mail for warrenbruno@comcast.net
never ever post emails, you will now get 10million spams a minute
for the rest of your life.
big error here. delete it now.
oops, fixya dont allow edits. bad to bone that...
Sep 29, 2013 | AccessData Password Recovery Tool Kit (ftk...
Can not find manuel on 29888gel anserwing machine can one be sent to me thank you mary aliantro 407 west evans blvd brigantine, new jersey 08203 kongss@comcast.net
You can download the manual from the manufacturer's web site at
http://www.home-electronics.net/USER-GUIDES/29888_DOM_EN_AN_IB.pdf
Jan 12, 2011 | GE 29888GE1 Digital Answering Machine
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Top rack dishes not getting clean
When the dishes on the top rack are not getting clean the most common problem is that the water supply hose in the rear of the top rack is misaligned. With the rack empty, pull out the rack and look in the rear where the supply hose slides into the water supply. Often a plastic clip or two has come apart. Realign everything and it will work fine. If you need a diagram go to sears direct parts where they have an excellent website. Enter your model number and you will be able to see a schematic showing each part and how they go together. Joe
please rate my answer as very helpful. thank you.
Apr 04, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
Nortong 360 by comcast....trying to install and I keep getting the error message..."error writing to disk"
Run the following symantec tool to remove old download manager entries:
https://www-secure.symantec.com/norton/support/special/sa/frm/_result.jsp?said=Dwn_Mgr_clean&productstyle=&prodid=
I had this problem as well as I used a Norton product before I switched to McAfee because of Comcast. The install worked for me after this simple tool cleaned the Norton Download Manager registry entries.
Feb 14, 2010 | Symantec Norton 360 for PC (037648318846)
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
The top rack on my kenmore dishwasher is not cleaning the dishes!
check the inlet strainer at the bottom of the unit - and also the nozzles on the top are for clogs/sediment.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 16, 2009 | Kenmore Elite 45986 Front Load Washer
Outlook Express Setup - error message
contact comcast and get the pop3(outcoming) address, and the SMTP (incoming) address
"mail.comcast.net seems correct but the outcoming smtp.comcast.net seems wrong.
Oct 13, 2008 | Microsoft Windows XP Home Edition
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
115 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
