Question about Philips Magnavox MS3252S 32" TV
JVC AV 32D305y won't turn on
I got this tv from a lady at my work. When it is initially plugged in, you hear one of the relays click, but when you push the power button there is no 2nd click. I have a green light on front so that tells me that there is power; so the fuse is good. There is no blinking, just solid green. I found a lot of posts for other JVC models that say to replace the C926 cap, but obviously the caps aren't labeled the same for each model so I replaced most of them. Does anyone have prior experience with this specific set? If so, please help...
  • cp12912 Oct 22, 2008
    I already changed that. Sorry that I didn't add that info in my initial post. I am giong to change the zener diode to see if that does the trick. Anyone else like to add something? Please help!
    Champion:
  • 252 Answers
Check the horizontal transistor at the back of plyback,it is a big rectangular parts with 3 pins
Posted on Oct 22, 2008
I have a JVC AV-65WP74, I went to bed watching the TV then turned it off for the night but the next day when I turned it back on the blue light came on on the TV but no picture, the TV makes a fast...
The clicking you hear is probably caused by a relay that controls the incoming AC to the main power supply. This is a protective reaction to a problem in the power supply itself or an overload due to a failure downstream from the supply. This is not a likely DIY repair. You will probably need a technician to determine which of these two likely problems it is.
May 19, 2011 | JVC AV-65WP74 Rear Projection Television
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
Jvc television want come on
Reset is done by unplugging the ac cord for a time,then plug
back in...............Please verify model number off sticker on the
                            rear of your tv...let me know.....T.
Oct 22, 2007 | JVC AV-56WP30 56" Rear Projection...
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
Philips Magnavox MS3252S 32" TV Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
