Question about Sony DHG-HDD250 200-Hours Video Recorder
TV Guide onscreen is the wrong time
All of a sudden the TV Guide onscreen channel lineup is wrong by aboout 3 hrs. It is not exactly 3 hrs off but if the actual time is 5pm the TV Guide that is being sent by our cable provider will show a time of 3:13. This of course throws off all the recordings and you can not set the DVR to record a certain show because it starts and stops at the wrong times. We have had this recorder about 1 yr and it has worked great until tis issue started. I have gone through the complete initial setup several times, even trying another zip code also local in our time zone but it does not solve the problem. Help. Gary
  • 6 more comments
  • Anonymous Nov 27, 2008
    My recorder was originally off by 20 minutes in the morning, then corrected itself before the next show at 3 PM.
    Today it is off by about an hour and a half and has not corrected itself.
    I think it is pretty short-sited of Sony to tie their recording mechanism to TV Guide - without the correct time, these DVRs are useless.
  • gatorbart3 Dec 01, 2008
    I've had similar issues when there has been a power failure in the past (resets to 12:00) but eventually readjusts to correct time within the next couple of hours.
    However, sometime over this past weekend has been out of sync with correct time (DVR time is 11hrs/20min earlier than correct time) and still has'nt correct itself as of Monday morning. Has been turned off during the night.
  • espineton574 Dec 04, 2008
    I have the same problem. The DVR had been going great for a couple of years all of a sudden 'round about Nov 30 '08, I'ts been off about 6 hours.Called cable they have nothing to do with this.Sony couldn't help me either.So it must be GEMSTAR. Could be SONY did not renew TV GUIDE contract.
  • cbeymer Mar 01, 2009
    I have this problem with four LG tvs. From what I have been told, this is a problem with TV Guide. They are negotiations with CBS to procast their guide, evidently it used to be downloaded through PBS and they lost their contract. The TVs are impossible to use the way they were intended to, and it frustrating because no one seems to be accountable for consumers not getting what they paid for when they bought these tvs with built in dvrs.
  • Anonymous Mar 02, 2009
    I have one of these DVRs and usually doing a soft reset fixes the time. However, this is not happening. The time comes from PBS, or did. It's possible they turned off the signal. I'm trying to figure out what other stations get the signal, since there's no menu option to set it. Meanwhile I'm going to try changing the zip code.
  • nickname20 Mar 02, 2009
    I have a later version of the tv guide software on my sony tv, the dvr was supposed to pick up the time signal from PBS, but according to an article I saw, PBS might not be sending that any more. On the tv, it said the time signal was already set, but by TV Guide. Possibly if the channel line was wrong, it might not know where to get the signal so changing the zip code makes sense. Make sure the channel lineup is correct. My DVR clock has been off for about two weeks.
  • ggprice Apr 08, 2009
    I've just begun experiencing this problem in Madison, Wisconsin. The time stamp used by TV Guide On Screen (TVGOS) was previously piggybacked on the signal of our local PBS station. Gemstar-TV Guide had previously contracted with National Datacast Inc. (NDI), a for-profit subsidiary of PBS, to provide this service. The contract shifted from PBS to CBS, but some local CBS affiliates have evidently elected not to participate in the national CBS program. That's apparently the problem in Madison.
  • Anonymous Apr 08, 2009
    I live near Detroit and my TV Guide stopped updating about a month ago. I've tried rebooting, to no avail.
    I can get PBS through Lansing stations. I'll try changing the zip.
I've had this problem before, and always fixed it by going through setup again, setting the zip code to another zipcode nearby, and turning it off overnight. By the next morning the time has fixed itself. This is the only thing that has worked for me consistently.
Posted on Feb 27, 2009
Samsung tv,,onscreen tv guide
You go to the menu with channel preference and for every channel that has the heart on it (a favorite) you highlight it for the small menu and hit favorite to unfavorite it.
Sep 04, 2017 | Samsung Televison & Video
Panasonic tv model TC-L55ET5 lost 3 digital channels with last update
Those particular digital channels may have been eliminated. The channel lineup changes periodically.
Nov 20, 2016 | Panasonic 55" L55ET5 Viera 3D Full HD...
Failed to receive broadcast e202
The 202 error is usually associated with a bad cable card. In your case, you need to check and see if you have one.
Did you run the Autoprogramming required to load and store the Channels?
If you are attempting to Add digital cable to your TV lineup, you must do that.
And one note -- the digital stations on your TV set will not match the lineup on the Cable box. The box was designed to line up the TV stations according to the guide, but it uses proprietary programming software and hardware to do that.
TV's cannot use the software. so you end up with the low to high frequency channels in your lineup, but it's not similar to the cable channel's lineup.
Try finding USA or TNT lickety-split....you won't.
After doing the full autoprogramming, let me know if you get only the Analog Channels from your Cable provider, or if you get NO channels locking in at all. Either one will likely require replacing the Digital tuner module.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 18, 2011 | Sharp Televison & Video
Says it requires 24 hrs time to program channels by zipcode 91042. Is this the case??
if you are programming a TV Guide type function yes.
The info is downloaded twice daily, around 2:10 pm EST and 2:10 am EST from your local PBS station.
The TV will wait for that down load before it gives any info in the TV GUIDE.
Apr 12, 2011 | Televison & Video
I have been receiving Guide Plus for the past 5 years, recently it does not work. I get the message, "No channel lineup has been recieved". I have tried to setup several times and all I get is the "no...
Hello. Unplug your set from the wall for two full minutes and then plug it back in and try it again. This will reset it. If that does not do it, call your service provider. J.
Sep 23, 2010 | RCA Televison & Video
The TV guide on screen no longer lists the tv schedule
Look online for the AVS Forum about TV Guide ON Screen (TVGOS).  there are lots of posts there about specific locations and providers,
May 18, 2009 | Toshiba RD-XS55 (250 GB) DVD Recorder /...
No channel line up in guide plus
Tune your TV to a Public Broadcasting Station before turning it off for the night. You should receive your line-up.
Oct 26, 2008 | RCA F32650 32" TV
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Onscreen TV Guide
The same problem occurred on my TV about the same time. I would be interested to know if you ever found a solution.
Sep 06, 2007 | LG 32LX1D 32 in. LCD Television
Sony DHG-HDD250 200-Hours Video Recorder Logo
2,826 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
