Question about GE 46GW945 46" Rear Projection Television
GE 46GW945 I have a GE46GW945 and it was working great until recently. Sound works great and the inputs are there. The picture however is distorted. at the top of the screen I have horizontal lines that break up the image or picture and it appears that it is showing a mirror image of what should be present. in the middle of the screen I have a solid black band across the screen. At the bottom I have red, green and blue color bands. I tried to access the software service adjustment but cannot see the screen to make the correct adjustments. can someone help...
    President:
  • 3,130 Answers
Your problem is a bad main filter, a regulator IC ,and or a combination of a convergence problem along with a vertical IC going bad. This set is not something you should mess with unless your a trained tech. Please seek a pro to assist you with this repair. good Luck
Posted on Jul 28, 2006
It won't turn on
I would check the fuse first and if thats good then I would suspect the flyback transformer
Apr 02, 2013 | GE 46GW945 46" Rear Projection Television
I have a GE model 46GW945 and it will work fine
I have a 1997, 19inch GE TV it comes on for about 10 to 15 minutes then shuts off and will not come back on until a few hours go by or so?? Anything will help Thank You
Dec 18, 2009 | GE Televison & Video
Sound but no picture
The first thing to check is the connections to your source. They can easily become loose and/or corroded over time.
Feb 25, 2009 | GE 46GW945 46" Rear Projection Television
Video sound problem
Camera not working properly. New - I would return and exchange
Aug 25, 2017 | Samsung NV20 Digital Camera
Convergence out power supply faulty for 46gw945 picture is distorted
You can get parts for your model by going to the following link and leaving them an email stating the model of your set and indicate which board you are needing. Heres the link
http://servicemanuals.vstore.ca/
May 05, 2008 | GE 46GW945 46" Rear Projection Television
HAS SOUND,NO PICTURE?
YOU'VE LOST VERTCAL DEFLECTION---THIS COULD BE SOME PARTS IN THE VERTICAL SECTION BAD,,LOST A VOLTAGE GOING TO THE CIRCUIT OR WORST CASE ----FLUID FROM THE PICTURE TUBES HAVE LEAKED ON THE CIR BOARDS CAUSING THIS PROBLEM---NEED TECH FOR THIS ONE!!!!!!!!!!!
Sep 15, 2007 | GE 46GW945 46" Rear Projection Television
Have sound but no picture
YOU HAVE A BAD CONVERGENCE IC ON THE CONVERGENCE CIRCUIT BOARD-THIS PART CAN BE REPLACED ,SAVING SOME MONEY,,COULD ALSO BE A LOOSE CONNECTION ON THE IC...PROBABLLY NEED TECH ON THIS ONE --COST 'BOUT 100.00 TO 125.00!
Aug 04, 2007 | GE 46GW945 46" Rear Projection Television
This set has a problem in the convergence power supply. The memory in the set thinks it is a direct view television since it cannot read the convergence memory. The convergnce power supply will have to be repaired to component level since the board is nla.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Nov 22, 2006 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
179 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
