Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Mfc -240c print problems
I have 2 printers and both suffer the same problem, one minute working fine and then one of the colors stops working - tried all the usual cleaning cycles but have come to the conclusion that the ink is not being fed through the little tubes, I pulled the printer to pieces and could see the ink moving in the tubes but the color not working also appeared to have a lot of air in the tube - how to flush or fill the tubes or to fix the problem?How does the ink actually get to the print heads somewhat uphill from the feed at the bottom of the cartridge?.I have tried all new cartridges - no change - Brother service people said new print heads will fix it??? only somehow I dont believe this unless the print heads also have some way of drawing the ink from the cartridges. hope you can help
  • 310 Answers
SOURCE: New ink cartridges not printing
there are 4 possibilities here.
1) the ink cartridge although appearing OK may have dried out or be faulty. If you have just purchased the cartridge take it back to the place of purchase for an exchange/refund.
2) not all the packaging has been completely removed. To check this remove the cartridge from the printer & make sure that ther is no plastic wrapping still on the cartridge.
3) the print nozzle is blocked. to check this go to control panel: printers & faxes right click on your printer then select properties. select the maintanence tab then do a nozzle check test. If the black does not print try selecting the clean & then deep clean items, If this still does not work remove the cartridges from the print head & see if using a soft lint free cloth you can remove any ink build up fom both the print side & the cartridge side of the print head. If this still does not work number 4 will apply.
4) your print head has failed. If u have warranty means better replace it..
Posted on Sep 07, 2008
crayzeetrayn
  • 837 Answers
SOURCE: How do I change the ink on a mfc-240c
Instructions for doing so begin on page 93
Posted on Dec 07, 2008
crayzeetrayn
  • 837 Answers
SOURCE: To find user's guide for a Brothers MFC 240C
Here is the link
Give me a FIXYA please .. thanks
  • 135 Answers
SOURCE: Brother MFC-240C
All Vista drivers for your MFC-240C Here:
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/download_index.html?reg=eu&c=gb&lang=en&prod=mfc240c_all&type2=1&os=74&flang=English&dlid=
Please be so kind as to rate my response thank you.
Posted on Mar 04, 2009
SOURCE: Brother MFC 240C alignment problems
I have figured it out! I have a Brother MFC 240CN and I was having the same alignment problem and I followed the instructions from the printer prompt as well as the manual and it does not work.
So, this is what I did. I ran the alignment test print, then when it asked if it matches, I would say "No". And then I would pick number "8" to be the one that most closely matched "0" regardless if it did or not. I did this for the 600 and 1200dpi. Then when I ran the alignment test print again, it looked better! So I repeated it again and again picking "8" each time and it looked better with every test print. After about 4 or 5 tries, it looked normal again!
I hope everyone else with this problem will see this response and I hope it works too. I was getting so frustrated with this problem. Now I don't have to get it serviced or buy a new printer!
Posted on Jun 02, 2009
My Brother MFC-240C printer is causing me grief. It prints out in black as though it is out of black ink but the ink is full. The other colors print out ok. Any thougths?
If the colors print OK, you could try cleaning the black nozzles. (Your machine may allow you to clean just the black or the colors, or all the nozzles).
1) Press the <Ink> or <Ink management> key
2) Use <Up> or <Down> arrows to navigate to "Cleaning" and press <OK>
3) Use <Up> or <Down> arrows to navigate to color that needs cleaning, or "All" and press <OK>
4) The display will show "Cleaning" and "Please wait"
5) After completion, the printer should be ready
If the problem persists, brother advises that you may need to repeat the process up to four times. If still no results, contact brother customer service.
Jan 22, 2010 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
My Brother MFC-3240C printer does not print crisp images. Colors are washed out and lines run though the images. I reinstalled the CD and no luck. Can you tell me what to fix?
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 25, 2009 | Brother MFC-3240C All-In-One InkJet...
Black ink in brother 240c printer does not print new cartridge
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black ink not printing even after changing the ink twice
try to clean the printhead or the cartridge by wiping it in the wet cloth...
maybe the nozzle of the black cartridge suffered clog..
you remove the clog by wiping it...^_^_
I hope it will solve you problem..
May 12, 2009 | Brother Multi-Function Center MFC-240C...
MFC 240C won't Print
have you tried to unplug the machine for twenty minutes then plug the machine back so that it will reboot?
Jan 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C NOT PRINTING
I just fixed my 240c by taping over the sensor inspection window on each cartridge, I used the same color tape as the cartridge, maybe blackwould work on all four but I had the colored tape so that's what I used. Works Like a charm I guess till the ink actually runs out.
Jun 28, 2008 | Brother Multi-Function Center MFC-240C...
Problem with Ink Cartridge
If you only want to print in b/w and do not use the color ones there is a workaround.
Please notice that you will destroy the C/Y/M part of the print head because the ph needs the ink to prevent a dryout!!!
Simply stick some adhesive tape around the window in the middle between the ink-outlet and the valve. The flag inside signals the printer the inklevel (and also the cartridge being installed).
Nov 24, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
